Genlemen,
Cobrazach, all the emblems at least for CR are put on regarding owners taste. For example the side badges are normally place roughly 1/2" above the vents and centered. Correct placement depending on when it was made the emblem would be almost 2"s (?) above the vents and all the way to the rear of the edge of the fender.
Skull/Knee busters are simply bolted on to the tubes that go to the frame. Their length determines where the plates will end up.
Side mirrors, everywhere-anywhere; my suggestion is sit in the drivers seat and have someone hold the mirror in place- Once the local is found- mount. Usually an inch (+/-) from the side of the windshield even at the edge to roughly a foot forward.
Thudmaster's signature line says it all!
