Old 11-09-2009, 08:57 PM
Randy Rosenberg Randy Rosenberg is offline
Cobra Make, Engine: SPF #1019
The engine stops because the battery switch should be wired to shut off all electricity to the car; ie: ignition. No igintion, no spark; no spark, no run.
HOWEVER, Blas never stated "where" exactly the fuel was leaking from the tank. If the tank is punctured, then fuel will leak regardless of whether there's battery power, or electric/mechanical pump, etc... And this can be problem.
