1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
12Likes
11-10-2013, 01:31 PM
KY
Because I can't tune for gas and a climate that's 2000 miles from me. You can't tune for low rpm low load operation anyway.
What if I tune for an air cleaner and filter here and he gets it in the car and the air cleaner is shrouded? That would make for a more richer tune and would need correction.
11-10-2013, 01:43 PM
But his elevation is only a couple of hundred feet higher that yours... and his 93 or 91 octane gas is pretty much the same as yours... and you have to tune it anyway, so you would think that you would welcome as many of the conditions that you know will be present when he drives his car to be present when you tune it? But, you're the builder, so I suppose you know best....
11-10-2013, 01:59 PM
KY
His gas is oxygenated. Mine isn't. He's prob at 70 degrees ambient temp, I'm at 30-40. Dyno corrects power to STP, but the engine is pulling ambient temperature.
You know, I don't know what some of you do for a living, but out of common courtesy I wouldn't barge in on a meeting with one of your clients/customers and argue about your procedures in front of them...
11-10-2013, 03:08 PM
Pat-you're exercising your court room skills in yet another academic argument of misguided consequence. I know you could just as easily defend the exact opposite argument if you chose to. Yet another display of intelligence is not needed.
The current state of the engine art simply operates on the knowledge that Brent explained. On anything other than purpose-built race engines (which are always dynoed with their race headers because they are integral to the tune) it is a given that the flywheel power gauges the engine's exact current power levels, at this particular tune and parts. RWHP is the more accurate gauge for what you're ranting about-the whole car's power levels in use.
So you sent your pipes out to the dyno, got your number, then put it in the car. Had you gone to the CHASSIS dyno, you promptly would have seen 17 or so percent less than your engine's number. What did that tell you? Of what value was your engine's power minus car?
In my case, after machining and assembly, my combination dynoed 550HP. I used 1 7/8" Galaxy Hookers with 10" collector on the dyno because the operator had no FE headers. The ERA uses 2" primaries. So what was my number? Maybe a bit more. But a year later, when Stainless developed the larger ID sidepipe, Lou sent them them to me to test. I went to the chassis dyno. The new sidepipes produced 49 more HP more than the original set (the prototype pipes from Stainless Specialties) and 5HP less than the open ERA primaries with collector. The peak was 462 RWHP and the math says that's 16% less for drive train loss. It correlates. THAT's the only other accurate way to know an academic number. But the original dyno testing told me I had a sound tune that was a stout street engine in 1991.
Brent and the builders test to optimize their parts selection, refine the fuel and ignition curves and observe the integrity of the build (leaks or porosity).
I watched 30 engines a month get assembled and dynoed. They spanned the major categories from SBC to Hemi and everything in between (except FE's). They were all dynoed with the same headers for their brand. As an example, the SBF's from 300HP to 708HP all got either of 2 headers. They differed by diameter and collector length. The sheets went to the customer with the engine. In rare cases a customer would send his headers because it was a specific race engine and he wanted us to optimize the combination around his headers. His 'chassis dyno' was his timeslips-which is the ONLY accurate way to determine relative power levels.
Begging all those points about wanting to know power at 1800RPM, the gas quality in Athens, the load factor of the brake, the humidity difference from A to B and such is not what engine dynos are for. A guy who uses that tool every day and explains that should not be persecuted to defend his methods. He knows the exact purpose of that dyno and uses it as such. That's why street-engine guys are often a huge pain in the ass to professionals. If you have years of time slips, lap times and changes in your resume, maybe then offer your differing point of view. Makes for good discussion when it comes from personal or professional experience.
Look we're lucky enough to have a few professionals who come on here and have the patience and donate their time (AND THEIR KNOWLEDGE BASE GATHERED OVER DECADES). They EDUCATE us-why not try to learn and not bicker with them about internet-mined 'facts'?? I'd love to have more of them but they have livings to make. Brent is currently the most generous that way. Sure, it's a way to generate business-that's as it should be for what he contributes. Plus, he's a mechanical engineer, he doesn't just pull this stuff out of his ass!
Let's don't drive him away by being dic-head street weenies with pendantic, debating-class arguments and always try to exhibit sophistication in his field of experience.
I for one, prefer to learn and question what I don't understand, not challenge.
Chas.
11-10-2013, 08:57 PM
SA
Brent - I apologize if I've offended.
It seems logical to me that verifying tune should include intake and exhaust setups imitating final installation setup, where possible. Hence my question.
This is a public forum, so surely it's open to anybody with a genuine opinion or question?
And what do I do for a living? I'm a chartered mechanical engineer.
Glen
11-11-2013, 03:21 AM
KY
Not offended by you Paul, I just thought it was poor taste to to start an argument in someone's build thread. I post these threads for a reason, basically so the customer will get a pictorial and detail-oriented step-by-step of the engine as it goes together.
If I were in Jeff's shoes, I would rather have a bunch of "atta-boy's" and "wow, that's a nice lookin' engine" than a bunch of guys arguing because the engine builder isn't doing the things that *they* would like to see done.
If you want to get down to it, an engine dyno will never simulate the true environment of the engine in the car. Sure, you can bolt headers and sidepipes on, and you can use the correct air cleaner, but what happens when you put the engine in the car and the hood shrouds most of the air cleaner flow? Should we dyno with the front end of the car around the engine then? What happens when you're shipping an engine half way across the country into a totally different climate, or half way across the world as I've done many times? Should we put humidifiers and heaters into the make-up air feeding the dyno room?
You can only do so much, and if anyone is *that* concerned about what horsepower their engine is making in real world conditions, they need to stick the car on a chassis dyno. Period.
11-11-2013, 03:36 AM
Vic
Two things:
1. Brent, I'm offended you let those poor soles offend you.
I thought you had more sense than to be baited by someone having a slow work day.
2. Now back to what's important. Only 11 more days to guess the hp/tq.
C'mon have a go.... What are you all chicken?
Or was my guess just that good? Surely not!
11-11-2013, 11:27 AM
CA
Torque would never be as high as the horsepower on a build like this, and I've never seen a 480-500 inch FE have over 600-620 lb-ft of torque on a normal hydraulic roller build.
We use a Stuska dyno, which shows anywhere from 25-50 hp lower than the DTS and Superflow stuff, so I told Jeff I was going to stay conservative on my guess.
But this is a solid roller build
11-11-2013, 11:28 AM
KY
True, but when you add more cam to raise the hp and the hp peak, torque will usually go down and the torque peak will usually go up.
11-11-2013, 11:36 AM
CA
As we discussed, this probably is a good thing for my use and car as it will be traction limited at low RPM anyway. I don't think this engine will be lacking in any department.
11-11-2013, 11:59 AM
Btw Patrick, I thought that you had a little more respect for me than to stick your head in a build thread just to insinuate that I'm not doing things up to your "standard."
Brent, you need to give Patrick a break. I just think it was slow day at the oyster bar for Patrick and I'll bet he often grows tired of debating which oyster is best, whether it's the Kusshi, Duckabush, Kumamoto, Cedar Island or the Beavertail oysters. I hear it can get kinda heated at times, a bit like the Shelby Cobra truest replica arguments here on CC. Patrick's motto is "one for all and all for me."
Lippy, nice engine build. Looking forward to hearing the final results and install.
11-11-2013, 12:40 PM
KY
I agree on both counts.
11-23-2013, 01:05 AM
Vic
Well, it's been a long time coming....
Had some minor technicalities with some parts, but finally got everything straightened out and moving forward.
Dyno'ing on the 22nd.
I'm a patient man... Really I am...
But it's nearing the 24th here (at least where I live), and I'm dying to know how it all went.
11-23-2013, 03:32 AM
KY
Had some rocker arm issues, so we are changing some parts around and gonna go back for a second go at it. We were at 630 hp, turning all accessories. Just didn't get a lot of time to try different things yet.
11-23-2013, 03:11 PM
Ia
Cobra Make, Engine: Hi tech 427 SC
Patrick will be somewhat impressed you had the accessories hooked up on the dyno so the tune will be more accurate er sumthn. Don't forget that air filter!
11-23-2013, 03:28 PM
Indeed he is.  Brent gets an A+ for his efforts in customer service every time. I'm curious as to what the rocker issues were though. And those HP numbers look pretty good from where I'm sitting.
11-23-2013, 04:13 PM
CA
The HP numbers look good to me also. I'll bet we get to 650+. And on a conservative dyno with accessories.
11-23-2013, 05:01 PM
Lemmee tell you... you will never, ever, ever, ever use that kind of horsepower on the street in a Cobra.  Whatever tires you have on there, when you stick the throttle, so that you don't break the tires loose much, but accelerate as fast as your total package allows, you can not do that safely for much time at all on the street. In fact, when you switch out the spring on your secondaries (which you mentioned you need to do in a previous post) you will be absolutely amazed at how difficult it is to safely open your secondaries fully on the street.
11-23-2013, 05:44 PM
CA
You're probably right. I think I'm going to start off with a throttle stop installed. But it's fun to build.
11-25-2013, 05:14 AM
KY
We may have lost 10 hp turning the water pump and alternator. Negligible.
One of the rocker stud inserts came out of the head. I'm cutting the heads and swapping the street T&D rockers for the race set. Not going to let this happen again.
Not a vacuum secondary carb.
Don't need a throttle stop, just don't push the pedal down all the way. Half throttle to 3/4 throttle is still going to get you more than 500 hp, way more than enough to kill you.....
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
