November 2024
Old 05-31-2010, 11:04 PM
Cobra Make, Engine: Johnex EQ
Default Tremec
Does the tremec tko II 500 have a electronic speedo output
Ed
Johnex EQ 514
Old 06-01-2010, 12:55 AM
PANAVIA's Avatar
in the TKO 500s I have seen, It can, but it does not have one in its native state. --
you need something to give you "pulses" for your E speedo to read.
not sure of the Roman numeral II reference - in the PN.
Old 06-01-2010, 02:47 AM
The newer TKO 500's and 600's have electronic speedometer outputs on the passenger side.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-01-2010, 03:56 PM
If not what part do i need?
Ed
Johnex EQ 514
Old 06-01-2010, 06:22 PM
The TKO 500 and 600 have an electronic speedometer pickup. You will need to equip your car with a speedometer that will read the signal.
Old 06-02-2010, 12:13 AM
I have the speedo (electronic). Whats the part I need to put in the tremec tko II 500, There is only a mach. speedo port.
Ed
Johnex EQ 514
Old 06-02-2010, 12:54 AM
Ant Ant is offline
Default Tremec
Gaugeguys sell a sensor that doesnt require magnets etc, you just mount this sensor to pick up something metal like driveshaft U clamp nuts etc.
EMP34 KIT, Speed Sensor M8 Cobra/Telemetrix
There is also a magnetic electronic speedo sensor available but Gaugeguys recommended the EMP34.............!
A J. Newton
The 1960's rocked!
