March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 10-14-2010, 06:28 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default Pin drive bolts coming loose
So last weekend I decided it was the perfect day to cruise through Napa. Somewhere along the way the pin bolts on my vintage wheels on the rear decided to come loose. I almost lost a rear wheel if it wasn't for an observant follower. I pulled over and jacked the car up and was able to tighten them up and get it home. I know for a fact I had torqued the pins down to 70 ft-lbs. What other options do I have to prevent the pins from coming loose on my adapter bolts and this happening again??
TIA
Mike
Old 10-14-2010, 06:48 PM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
TIA
Mike
Loctite?
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
Old 10-15-2010, 05:11 AM
TButtrick's Avatar
TIA
Mike
I've never heard of that happening before. There might be something else going on there. You sure the mating surfaces are clean and no obstructions that would prevent the adapter to seat fully on the rotor face? Check that the center of the adapter is clearing the center of the axle or spindle hub as well.
Old 10-15-2010, 05:26 AM
undy's Avatar
Per Vintage, 85 lbft with red lock-tite. That's what I did to mine... 70 lbft is inadequate, IMO.
Too many toys?? never!
Old 10-15-2010, 05:54 AM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
http://www.vintagewheelsus.com/tech.php
"Wheel studs used must be of the correct grade as supplied by the hub/axle/spindle manufacturer or from a reputable aftermarket wheel stud supplier.
Drive pin lugs must be installed using high strength thread locker and torqued to the manufacturers specification. The typical torque setting for a ½ inch x 20-wheel stud is 85 ft lb."
Pics---> www.jmimac351.smugmug.com
Chief Instructor: www.ChinTrackDays.com
Old 10-15-2010, 01:32 PM
Alrighty then.. I will take them off this weekend and do them per the spec of 85 and some loctite. Don't want to be losing my wife when she drives it because I have loose nuts..
Old 10-15-2010, 03:40 PM
Senior ClubCobra Member
I've not heard that Vintage had a problem, but consider this thread.
Pin drive bolts splitting Help Please
