November 2024
Old 10-19-2010, 08:38 AM
Cobra Make, Engine: various,289 HiPo
Default Windshield clearance to body?
I am just about to install my windshield and wonder what should the clearance be between the lower metal frame and the body. I did a search and found windshield angles but not clearance. Any thoughts?
Old 10-19-2010, 08:58 AM
Rick Parker's Avatar
I don't think there is any set specification for your concern. The rubber seal strip will create some small clearance but you could slide some strips of thin cardboard (or similar) under the frame prior to tightening the mounting bolts. These would then be removed. an extra set of hands helps out considerably. Just an idea.
Rick
Old 10-19-2010, 09:16 AM
StewbieC's Avatar
Cobra Make, Engine: Hawk 289 with 65 289 SBF
Mine's about 5mm or 3/16" gap and the rubber strip lies plenty flat at that.
Hope that helps.
Stu
__________________________
Building a Hawk 289 Slabside.
Powered by a 65 289 FORD
Old 10-19-2010, 11:20 AM
Default Thanks
That's what I needed. I knew the metal frame did not rest on the body.
