1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
11-24-2010, 08:48 AM
I'll say!
Originally Posted by Paul F
Grumpy old men.....
I'm with you, Paul. That Chas needs to get a life....
11-24-2010, 08:57 AM
Ill
Sooooo Patrick
what kind of locknuts are on your engine mounts? or bell housing????
11-24-2010, 08:58 AM
Originally Posted by Jerry Clayton
Sooooo Patrick
None, on either.
11-24-2010, 09:11 AM
Ill
you need to correct the washers on the bolts in your pressure plate and also why aren't you using the dowel pins for where the pp joins the flywheel??
And your quick jacks
11-24-2010, 09:17 AM
OR
Okay, so what is everyone using is places where you use a bolt threaded into a threaded hub where obviously a lock nut can't be used? A belleville washer?
11-24-2010, 09:19 AM
My overpriced Centerforce aluminum flywheel had no dowels -- loctited ARP shouldered bolts though. I do use the split lock washers on the starter motor and, as you can see from the photo, I have to retighten them ever few months.
11-24-2010, 09:31 AM
Eleven thousand eight hundred and ninety five posts and I need to get a life?
So Paul, we relics should be eternally grateful that our boy here relentlessly educates whippersnappers like you?
Chas.
11-24-2010, 09:45 AM
Surely you're not suggesting that the QJ nuts should go inward?
11-24-2010, 10:53 AM
Two pages so far on lock washers?
What is this world coming to?
11-24-2010, 11:07 AM
Full Blown Member
Look, let's just safety wire it, spot weld the lock washer under a nylon locking nut, JB Weld a small square of mirror on it and place an energy efficient spotlight on it. Simple.
rodneym
11-24-2010, 11:14 AM
TX
This thread needs some "Threadlocker," and I ain't talking the stuff in the red tube.
11-24-2010, 11:27 AM
Full Blown Member
rodneym
Reason: my internal spell check is much slower than my fingers
11-24-2010, 12:22 PM
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Try your local hardware shops for a product called 'Nordlock', two piece 'ramped' & 'serrated' washer, only good for RH threads, works great on headers, manifolds, bell housings. Needs a couple of rechecks when used in alloy applications as serrations tend to 'bite' into the softer alloy.... might be just what you need on those 'FE' intakes to keep the bolt clamp pressure up.
Jac Mac
11-24-2010, 12:28 PM
Thanks Jac for something constructive out of this.
Chas.
11-24-2010, 12:44 PM
I'm betting I'll get slammed for this, but is this option?
http://www.stage8.com/
11-24-2010, 12:47 PM
Originally Posted by RodKnock
I've never used them -- but the guys on the PowerBlock, Stacey David's shows, Truck U, etc., speak highly of them. But, they could be paid to do that, I don't know.
11-24-2010, 01:31 PM
Lock Washers are useless!
Found this information
Quote US Navy:
Naval Ships' Technical Manual, Chapter 75:
"Although lockwashers may be encountered, using the flat washers with selflocking nuts, self-locking fasteners, self-locking inserts, or thread sealants such as MIL-S-22473 anaerobic compounds is preferable.
A flat washer is used for many purposes, some proper and some not. The two most common proper purposes are:
1. To distribute the pressure of the nut or bolt evenly over the part being secured, reducing the chance of damage thereto, and
2. To provide a smooth surface for the nut or bolt to bear on, making it less likely to loosen as a result of an uneven fastening surface.
Bottom line use flatwashers and if not sure or the part is inaccessible use the correct thread lock and as mentioned Loctite Blue or medium strength is generally sufficient for general automotive applications, if you want to get it apart. For the newcomer Dont use Loctite 262 on your knock off wheel threads or any thread lock for that matter as the larger the thread the worse the problem can become to undo!
A J. Newton
The 1960's rocked!
11-24-2010, 01:57 PM
Senior ClubCobra Member
Ca
Chas,
You can do as you like with Patrick. He doesn't seem to mind.
11-24-2010, 02:13 PM
Patrick wears his heart on his sleeve. The cruel, caustic commentaries by Chas cuts him to the quick.
11-24-2010, 02:21 PM
Chas,
Sigh.... You are correct-it only glorifies him more.
But every hamlet needs it's Village Idiot. (Wish we had a VI smiley guy).
Chas.
