January 2025
26 27 28 29 30 31
  #361 (permalink)
Old 08-16-2011, 05:44 PM
I don't know the guy....but I know that he uses good parts...ARP stuff and parts from my buddy Doug Garifo....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #362 (permalink)
Old 08-16-2011, 06:19 PM
POP! Yes quality stuff from both.
Chas.
  #363 (permalink)
Old 08-16-2011, 06:22 PM
... and I reckon it looks something like this:
  #364 (permalink)
Old 08-16-2011, 06:24 PM
Yup.......
Since I'm a distributor for Pro Gram, I thought hard about using their billet cross bolted caps, but it would require a lot more machining and I have my theories about how the girdle would be stronger. We'll see.
  #365 (permalink)
Old 08-16-2011, 08:33 PM
From post #120:
My goal is to hit about 600hp at around 6500. The heads will play the biggest role in that.
Now that bridge on the bottom end makes sense. A 1.35 motor. The heads will need to be 350 or so, no? Also, I found the cams' lobe lifts but not the gross lift. Please enlighten (or repeat if I missed).
Chas.
  #366 (permalink)
Old 08-17-2011, 02:44 AM
Heads will have to be "special"....
Lift at the valve is around .630" with a 1.76 ratio.
  #367 (permalink)
Old 08-17-2011, 07:21 AM
It should be easy to do. I make 550 with a .633 exhaust and 320 heads-with less displacement-427.
Chas.
  #368 (permalink)
Old 08-17-2011, 09:14 AM
... and you're putting that motor in a pickup truck?
  #369 (permalink)
Old 08-17-2011, 10:09 AM
That's the plan.
  #370 (permalink)
Old 08-22-2011, 05:19 PM
Well here's your update, Patrick.
Thought I would take a break and work on my own stuff, since it is my birthday and everything.
Got the girdle mocked up, matched the oil pump feed hole from the girdle to the block, then started to drill/tap all the lifter galley holes for pipe plugs.
Got 2 done, broke a tap.
I'm done for the day.
  #371 (permalink)
Old 08-22-2011, 06:05 PM
Default OK, I know what the problem is...
... you probably had too much pressure in the keg. If the beer comes out all foamy, then there's too much pressure and you'll break your tap.
  #372 (permalink)
Old 08-23-2011, 12:52 AM
Ouch!! is it stuck in the block?
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
  #373 (permalink)
Old 08-23-2011, 04:20 AM
Yep, stuck in the block.
  #374 (permalink)
Old 08-25-2011, 01:09 AM
Bummer!
Paul
  #375 (permalink)
Old 08-25-2011, 02:43 AM
No biggie, got it out....
  #376 (permalink)
Old 08-25-2011, 07:22 PM
Sminor's Avatar
Cobra Make, Engine: Shell Valley Roadster,428FE, 2X4's; 1966 GT 350 Clone; 1968 Shelby GT-350
Hey Brent,
Haven't had time to check all the posts in the last few days. HAPPY BIRTHDAY!!!! I wish you many happy returns to the day (broken tap notwithstanding). Hope the family is doing well.
steve
  #377 (permalink)
Old 08-25-2011, 07:49 PM
Thank you Steve....much appreciated.
All galley holes are tapped now....block is ready for machining.
  #378 (permalink)
Old 09-02-2011, 05:39 AM
Default She's at it again...
Well that secretary of mine is at it again. Not only did she tickle today for a progress report from you on how you're coming on the engine but she even flagged a note to make sure you didn't leave that little plug out that goes behind the distributor. She says that you're going to forget that plug and then you won't have any oil pressure. I said you're brighter than that, but when she gets something in her head she can be tough to deal with so it's best to just get out of her way. I told her that since it's a Friday before a three day weekend that she should just knock off early, but she said she won't do that until you post an update. So maybe you should get to it, just to make my life a little easier.
  #379 (permalink)
Old 09-02-2011, 07:13 AM
Oh brother.....
  #380 (permalink)
Old 09-02-2011, 08:00 AM
Oh brother.....
The gift that keeps on giving...
Chas.
