February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 07-01-2011, 12:58 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Need Help No brake lights with VW Turn Signal Switch
Please bare with me as I'm a wee bit slow sometimes comprehending how wiring functions.
I installed the wiring for the VW turn signal switch last night and the turn signals and parking lamps work correctly, but i do not have brake lights.
- Brake switch is receiving 12.5 volts
-12.5 volts passes through the switch when the brake pedal is depressed and returns to the terminal that plugs into the dash.
Now this is where i get confused. The 12 volts feeds out of the fuse panel to the switch and when the switch is activated by depressing the brake pedal, the 12 volts feeds back to the terminal at the turn signal indictor. Now, the wiring harness has a wire that provides 12 volts to the indicators when the ignition is in the on position. It connects to a Black wire with Green and White dashes on the VW Turn signal switch. Off of this Black wire with Green and white dashes is a bright blue wire. The power to the bright blue wire is cut when the either left or right turn signals are activated.
What does my return wire from the switch hook up to and how does it work? I assume that the return wire from the brake switch must feed into the turn signal switch somehow so that when the left or right indicators are activated, that particular sides brake light shuts off and the bulb then becomes the indicator instead of the brake light.
Help please!
Thanks
Old 07-01-2011, 04:49 PM
You need a relay that integrates the brake and signal light signals into a single signal. The original box is about 3" x 2" x 1.5" and is usually mounted on the firewall next to the fuse box. Do you have one?
Old 07-01-2011, 07:37 PM
mickmate's Avatar
I use a trailer light converter which is essentially a couple of diodes. We connect that in line so it doesn't back feed when you have two inputs to the tail lights from brake and directionals.
mickmate
http://www.actoncustom.com/
Old 07-02-2011, 09:00 AM
Rick Parker's Avatar
Tail Light Converter (12") :: Hopkins Towing Solutions
Use a #48845
This is for applications using one bulb per side with 2 elements.
They are available at most major auto parts stores, I got mine at Pep Boys.
Rick
