January 2025
26 27 28 29 30 31
Old 04-30-2012, 03:59 PM
Default Right engine bank slapping noise
The right bank has developed a slapping noise. I was wondering if it is a broken or damaged lifter?
Old 04-30-2012, 08:07 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Bad lifters are usually described as a ticking noise. Slapping sounds more serious. Time to listen with a stethescope.
Old 04-30-2012, 08:09 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Take the valve cover off and look to see if it is a rocker.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 05-01-2012, 07:53 AM
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
Every once in a while an exhaust leak at the header can make a noise that can fool you into thinking it's a mechanical problem. Without hearing the noise you're describing, I don't know if this is a possiblity on your car, but just wanted to pass it on...
When I said I wanted to be somebody, I probably should have been more specific...
Old 05-01-2012, 08:13 AM
Cobra Make, Engine: Factory Five, 302
I second what Dirty Harry said. I had a similar experience with an exhaust header leak. Sounds awful.
Old 05-01-2012, 11:40 AM
If you can't see something broken with the valve cover off. (Engine not running)
Warm it up a little, then take off the valve cover again. Start the engine and take a look.
Old 05-03-2012, 06:12 PM
found the problem, blew a header gasket. Thanks for all the info on my problem.
Old 05-03-2012, 07:57 PM
Average Guy
Thank goodness it was something fairly easily fixed and fairly inexpensive. Curious, how a leak there will fool you into thinking you've got bigger problems.
