1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
1Likes
06-19-2012, 11:25 PM
TX
Originally Posted by ERA Chas
And yes, you can get enough of that sound from a top- oil 390-445 / 500HP build from any of our resident builders for at least $5K less than the legend. A mild .500" lift SFT cam will give enough audible chaos to dazzle the parking lot sheep and tingle your toes.
Who the hell appointed you the voice of reason? I need to make sure you don't talk to my wife before I launch into my next unneeded purchase (which may very well be imminent.)
06-19-2012, 11:31 PM
Chas does have a way with words.
06-20-2012, 04:25 AM
Well sorry my learned colleagues-I'm gonna F it up.
Nowhere has this guy said he's looking for the last HP, lowest lap time, 24 hour endurance or last hundredth. He just wants to have the sound that you bad-asses do.
And yes, you can get enough of that sound from a top- oil 390-445 / 500HP build from any of our resident builders for at least $5K less than the legend. A mild .500" lift SFT cam will give enough audible chaos to dazzle the parking lot sheep and tingle your toes. Which seems your priority.
You can build that killer SO when you're less concerned about how it sounds and more interested in port velocity, head flow, cam events and blueprinting specs.
Which may never happen.
We got another guy here who waxes (literally) incessantly and sublimely about the noise his FE makes with exactly the same non-SideOiler combination I outline above. He spent the saved money on extra rollbars and pedicures.
His name starts with Patrick and ends with a .......
Chas is absolutely right (ehrr, not on the pedicure thing, though). The OP should just do what I did. 500HP will be plenty for him and his engine will still be pulling strong long after he's pushing up daisies....
06-20-2012, 05:08 AM
Me
The OP should just do what I did. 500HP will be plenty for him and his engine will still be pulling strong long after he's pushing up daisies.... [/quote]
Assumed this was to be posted sooner or later.
06-23-2012, 04:21 PM
AR
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Tell us how you really feel!
Thanks for your easy to understand remarks!
There were no atheists in the foxholes.
06-23-2012, 04:26 PM
AR
06-24-2012, 04:15 AM
Me
I hear you all about the BB sound all the motors in our hot rods have been 454" or bigger since the 70's.A couple of years ago picked up a 406" roller cammed sbc powered bike this engined dynoed 580hp.Been a long time since I played with the sb stuff and with todays technology especially in the breathing dept (heads intakes exhaust and carbs) Truly incredible how much the after market has massaged the sb the flow cfm Except for lacking in physical dimension am more than impressed with the whole package.Because of the lack of physical dimension this motor will be replaced with an aluminum Donovan sbc with SB2 topend expecting near 800hp so watchout bb powered stuff.PS FE boys come listen we can compare sounds these pumps generate.
06-24-2012, 06:58 AM
Originally Posted by mdross1
... this motor will be replaced with an aluminum Donovan sbc ...
Uhhh, didn't he, like, sing "Hurdy Gurdy Man?" Why on earth would you forgo an FE for that?
06-24-2012, 07:34 AM
wa
What a shame.
Drinking like that so early in the morning.
John Hall
06-24-2012, 10:23 AM
Me
That was a trip in time, forgotten all about that 60's original hippy.An FE in a motorcycle? Now that would have to be a dedicated move.Actually did consider the spare 460 sitting under a bench but wanted an all aluminum motor and 800hp.
06-24-2012, 01:55 PM
PA
800 hp is useless on the street.
I will run you with 5 fitty any day of the week.
06-25-2012, 05:01 AM
Me
Sure would be fun,my car is in the 580hp range.This expected 800hp Donovan is being built for a motorcycle once dailed in you pick the day and the place.
Trust me no amount of hp is wasted on the street for some of us anyway.There are boys running around with power that would make mine look like a Yugo.
06-25-2012, 05:33 AM
PA
I will pick the road........
Bring it
06-25-2012, 11:18 AM
What a bunch of pussies. I say we put the gloves on both of you and give you three, 3-minute rounds, and see who's left standing.
06-25-2012, 11:22 AM
PA
With you standing in the middle
06-25-2012, 11:24 AM
Full Blown Member
That'll clear up who has the faster/better/et al, replica!
rodneym
06-25-2012, 03:40 PM
What happend to original question about BB sound????
06-25-2012, 03:53 PM
I think we're waiting on Patrick to post the results from his acoustical comparison between the sideoiler FE and non-sideoiler FE, the SBF and finally the SubZero refrigerator. Once the information is posted, we'll be able to definitively give PHC1 an answer to his original question.
06-25-2012, 04:44 PM
PA
Excellent. Rod you have been Repped
06-25-2012, 05:12 PM
Oh
Well since Patrick peaked my interest, I paid attention at the London Ohio Cobra show. I tried to locate the FE cars and only found 6, 8 counting two vender display cars. That is out of nearly 200 cars. Now there were a lot of cars with hoods down, so there certainly had to be more. I did see some more FE cars earlier in the week, but I didn't want to double count. I also counted 4 385 series big blocks.
I can say if you have a near stock 300 HP or less SB, they are pretty easy to tell. When you get to the engines making good power it gets very difficult to hear a difference as the power goes up. However the one thing that stuck out is the BB all had the milder sounding cams.
Why the milder cams? Well I could speculate that they just don't need them to make the power, and that is likely true. Also more cid tends to sound milder with the same cam specs, all else being equal, but remember some of the SB were bigger cid than some of the FEs.
Now not all FE's sound alike. I met a fellow with an all aluminum 460 cid FE with tunnel port heads. It had a fairly mild cam (hydraulic roller) with a C6 transmission behind it. I think it had the sweetest sound there. He showed me the dyno sheet. Practically flat torque curve around 600. Torque was only down to 550 @ 6700 rpm where they stopped at 650 Hp. It looked like it wouldn't have peaked before 7500, but that is my speculation. Torque was over 500 where they started the pull at 3000 rpm. The car is fast. Oh yea it was in an ERA too. Great guy to talk to too.
