November 2024
Old 06-12-2013, 03:46 PM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Any idea how to insulate underhood area ??
I have some left over of Lobucrod heat barrier stuff and I would like to insulate the inside hood but I have no idea how to approach it. I would like to do a professional job so when you open the hood it looks nice.
Can anybody share his expertise on this please, thanks !
Michel
Old 06-12-2013, 05:24 PM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Michel
Why would you want to insulate the engine compartment? You want to get the heat out of there.
You might insulate the firewall to help keep heat out of the cockpit.
Old 06-12-2013, 07:00 PM
I haven't driven my car a lot since completion and was wondering If the heat in the engine bay can damage the paint. I did put that stuff on the firewall though and it makes a big difference in the cockpit.
So I shouldn't worry about the underhood !
Old 06-12-2013, 11:50 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
I used a hi-temp glue and carefully cut and placed insulation on the underside of my hood. It looked great for about two years and then started to sag. This got annoying and so I pulled it off and was left with yellow glue globs and streaks on the underside of the hood. I was embarrassed to open my hood, so I took the hood off and sanded (and sanded and sanded) with a pneumatic random orbital sander and finally got all the glue and blistered bedliner (the original finish from my painter---also not a good idea) sanded off.
I have some VHT primer and paint that I'll refinish the underside with in a week or so.
So, I'd say forget about the insulation. If you are concerned about heat damaging the top side of the hood there is a guy back East that sprays an aluminized paint that reflects the heat. Bing/Google "Metalmorphis Cobra" and you should find him.
You can make the insulation look good for a while, but eventually the glue will give out. There are better ways to finish the underside of the hood.
DD
Dangerous Doug
"You're kidding, right?"
Old 06-13-2013, 05:44 PM
Default I'll leave it !
Maybe I should leave it, I don't drive the car that much anyway, Thanks guys for the advices !
