T-5 ?
http://www.clubcobra.com/forums/all-cobra-talk/121093-t-5-a.html)
kennyhbh |
06-15-2013 10:11 AM |
T-5 ?
Hi Guys, I'm going to be changing out my speedo from mechanical to electronic. I'm going pulling out speedo cable and plugging it. My question is will tranny fluid be coming out when I take out the cable ???
Seagull81 |
06-15-2013 05:06 PM |
No oil won't come out, but where are you going to get your signal for the speedo? I replace the mechanical one with the sender that came with the gauge kit. It went in the same place as the mechanical one.
kennyhbh |
06-15-2013 06:58 PM |
on the other side , were is a electrical plug in.
Gaz64 |
06-15-2013 07:29 PM |
If your trans has a cable driving the speedo, you remove the cable only, then fit your Vehicle Speed Sensor in place of the cable.
Your T5 has no other means of providing a vehicle speed signal.
What's on the "other side"? Only reverse switch?
kennyhbh |
06-16-2013 05:10 AM |
Sorry guys I meant to say TKO 500
Ron61 |
06-16-2013 05:29 AM |
Kenny,
I ran a built TKO 500 and I used the electronic VDO gauges as the speedometer is easy to calibrate after a tire size change or gear change. The Hall Effect sending unit screwed right into the same hole as the mechanical gear unit would go in. I had a Neutral Safety Switch that was electric but I can't recall just where it was located on the transmission.
