1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
07-20-2013, 11:32 AM
ESP
Cobra Make, Engine: NAF 289 Blue/White strips
Ignition distributor
Hello from Spain
can this movement or gap on the distributor cause irregular pinging noise?
Rico
Distributer - YouTube
Rico, NAF 289
07-20-2013, 12:04 PM
tx
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
That play looks normal, you're moving the mechanism against the mechanical advance springs.
If your engine is pinging, typical issue is is it has too much total ignition advance. What is the initial timing set at? Should be around 10 - 14 degrees of initial timing, with total advance no more than 36 degrees total.
Also the quality of the fuel has a lot to do with the pinging (pre-ignition). If it's a higher compression engine than the quality of fuel you are putting in the car, it will ping.
We have 87 octane regular quality unleaded at the pump and you usually can't go over 9:1 compression.
07-20-2013, 12:19 PM
Ut
Cobra Make, Engine: 66 Cobra
Also, take the rotor off by removing those two screws on the top. Make sure both of the springs are connected.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
07-20-2013, 03:01 PM
PA
Originally Posted by cobra 53
Hello from Spain
Rico
like racer x said that is normal, i watched your other videos about the engine noise, it just sounds like valves may need the lash set.
the cam seems mild but your gauge only shows 12 in vacuum at idle...my seat of the pants says it should be more.....
Fred B
07-21-2013, 03:42 AM
ESP
Thanks for the replys.
The problem starts with the higher summer temperatures. 91F-94F.
Gasoline 98 OCT (us 93).
Idle 840-880 RPM. Vacum idle 10-11.
Initial timing 12°, total 33°. Blue bushing, 2 blue springs. Mech advance.
Idle AFR 13-14. Driving AFR 13.5-14. LM2 in the car.
Compression 10.0-10.5. Highest is cyl. nr. 6 with -11.0.Water 190F. Oil 180F.
Cam is CompCam 31-760-8 / 288R
Starting the engine is no problem. No chock. No noise until engine heatet up.
The noise appers irregular on the driver side valve bank next to the distributer and the cyl. nr. 6 and 5. You can hear the nois aswel as little high clear note in the sidepipe.
Rico
Rico, NAF 289
07-21-2013, 05:58 AM
tx
You need to reduce the total timing or limit it. Reduce the initial timing to 10 degrees and see if it pings. Do you have an advance timing light to check total timing? My guess is total timing is more than the 33 degrees.
07-21-2013, 12:44 PM
Ca
Premium fuel.
Rick
07-21-2013, 12:51 PM
tx
Why do you state the compression is higher at 11.0:1- in cylinder #6?
That will cause the pinging when compared to the others at 10.0 -10.5:1
07-21-2013, 01:44 PM
ESP
Super unleaded 98 Oktane Gasoline is corresponding US Premium
-11.0 compression wil be checkt to morow morning. Aswell the valve lash and ignition timing. Comp Cam says 0.02 inch gap. Cold or warm engine ?
Rico
Rico, NAF 289
07-21-2013, 03:00 PM
PA
Rico
usually their lash specs are for warm.....
Fred B
