February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree9Likes
  #21 (permalink)
Old 03-21-2014, 06:02 AM
Thor maine's Avatar
Since The Gumball Rally started me on this crazy trip, those are the vents I want to put in. They look fantastic.
  #22 (permalink)
Old 03-21-2014, 07:32 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Thanks for all the input & pics guys, I favor the Maier Racing GT 500 louvers that Dallas installed . I think they look the best.
Blas: yeah, it's permanent, but no worries as I happen to have a SPARE HOOD !!. I figured I could modify one if necessary to clear the webers, and keep the other stock.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
  #23 (permalink)
Old 03-21-2014, 07:38 AM
MOTORHEAD's Avatar
Thor: What started me down the Cobra path was Peter Klutt's TV show "Legendary Motorcars" show many years ago, where he was restoring an original (289 or 427, don't remember which), and one thing he had to do is remove two hood vents and patch the holes. I never missed a segment of that show, and now it's back on Velocity tv on tues @ 10 pm.
  #24 (permalink)
Old 03-21-2014, 07:46 AM
MOTORHEAD's Avatar
Migge: I've seen those on flea-bay, and actually the surface mounting with poprivets (which on any other car would be considered "tacky") actually works on the Cobra, since the adjcent air scoop is done the same way, not to mention the pop rivets at the front of the hood.
  #25 (permalink)
Old 03-21-2014, 08:30 AM
dallas_'s Avatar
In the interest of full disclosure I found my Maier louvers needed quite a bit of work to make them look good. I filled in a few pinholes and areas that were thin, sprayed them a couple of times with high build primer and spent far more time than I would have liked sanding them smooth. And sanding those corners was a pita for sure.
Maybe your set will be better, but be aware just in case.
  #26 (permalink)
Old 03-21-2014, 09:32 AM
MOTORHEAD's Avatar
Dallas: I saw a pair on flea-bay that were fiberglass, seller said they were gt500, new, never installed, don't know if the were Maier's, but he said they were not usable as recieved, needing finishing, and the openings weren't even cut out !!
Don't think I'll do those after all, I'll try something else.
  #27 (permalink)
Old 04-08-2014, 04:14 PM
Cobra Make, Engine: SPF 239
This is what i did
mando s and kmn5 like this.
  #28 (permalink)
Old 04-08-2014, 04:26 PM
dallas_'s Avatar
I like that.
Can we see more details and maybe a couple of close ups and what it looks like under the hood?
  #29 (permalink)
Old 04-08-2014, 04:41 PM
mln385's Avatar
Cobra Make, Engine: BDR
Check the area around the radiator intake. Is that area well sealed? I put weather stripping around the radiator and cowl along with a bigger radiator and it solved my issues.
You could actually hear the difference in how the air circulated and is now pulling through all the radiator surface instead of around it.
  #30 (permalink)
Old 04-09-2014, 05:29 AM
mdross1's Avatar
This was my solution used the same radiator but custom cut aluminum panels to fill the gaps.
  #31 (permalink)
Old 04-09-2014, 05:06 PM
mnm99's Avatar
Sorry to steal a spot here. I'm looking to poss buy this car. It has louvers also. If caught in the rain wouldn't that cause a bit of a problem?
  #32 (permalink)
Old 04-09-2014, 06:18 PM
Senile Club Cobra Member
Nah.....just water spots on the polished aluminum. No running issues.
rick@autoventureusa.net
  #33 (permalink)
Old 04-09-2014, 08:41 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Water getting in through the louvers is the least of your problems with a topless car
  #34 (permalink)
Old 04-09-2014, 11:42 PM
Cobra Make, Engine: Shamrock
That's great - I don't think rain will cause much problem but would make sure alternator is shielded.
  #35 (permalink)
Old 04-14-2014, 02:01 AM
FatBoy's Avatar
Cobra Make, Engine: Kirkham #523, 427 S/O
These are the louvers on COB6008:
They were originally "installed" for the 1965 Angolan Grand prix.
Paul
xb-60 likes this.
  #36 (permalink)
Old 04-14-2014, 02:22 AM
xb-60's Avatar
Interesting. They are all different lengths on COB6008, so would need multiple tools to punch them.
  #37 (permalink)
Old 04-14-2014, 01:47 PM
G-Pete's Avatar
No, you just need a bead roller.
DRB GT40 MK1 red #49- sold
SPF 2063
  #38 (permalink)
Old 04-14-2014, 04:35 PM
xb-60's Avatar
Thanks G-Pete. I just educated myself!
[ame=http://www.youtube.com/watch?v=_YcgwxjmGS4]Louvers in a Bead Roller? - YouTube[/ame]
Last time I punched louvres in a car hood was ..... a long time a go. That was with a conventional punch and die.
Glen
  #39 (permalink)
Old 04-17-2014, 11:31 AM
Cobra Make, Engine: ERA 148 Nightwatch Blue
Some metalmorphous louver work
xb-60 likes this.
  #40 (permalink)
Old 10-14-2021, 07:34 PM
Cobra Make, Engine: KCC, Chevy 5.7
Originally Posted by MOTORHEAD View Post
I'm thinking hood vents will help, such as Morris or Dallas have.
Sorry to bring up an old post.
By chance anyone here have pics of the vents Morris has, I'm a bit curious how stainless steel marine ones look on the hood.
Thanks
EDIT
Never mind, I found them
Actually I like the look of the vents
