February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 05-28-2014, 05:32 AM
Rawkkrawler's Avatar
Cobra Make, Engine: Everett Morrison
Default Slightly different alternator question
All,
I've searched and searched and could use some additional help..
I'm using a 3G alternator and did not use the green output wire (I) as I do not have the instrument light. I'm not getting any voltage at this point. The yellow (A) is hooked up to the battery, and the wh/blk (S) is tied to the spade connector at the alternator.
So my question, do I need to tie the green wire (I) to the switched ignition source to "excite" the internal regulator? I've seen one diagram with it wired this way. If so, is there a resistor needed? I know some go through the indicator light.
And if the answer is yes, can I use the same 12 volt ignition wire feeding my Mallory Hifire distro (only because the wire loom is already in place and I'd rather not pull it apart).
Note: the alternator was tested and it works fine.
Thanks in advance!
Mike
Mike D
Tampa Fl
Old 05-28-2014, 10:35 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Yes, you need an exciter wire. Usually a resistor is used in parallel with a light so if the light burns out, there's still voltage on the exciter wire. Wire going to the distributor should work.
Old 05-28-2014, 11:03 AM
Thanks!
Mike D
Tampa Fl
