February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 06-08-2014, 08:02 PM
Default Alternator Voltage Regulator help
I discovered that one of the wires from the voltage regulator ends in the wire loom and is not connected. According to the drawing in this link, that wire should go to the alternator stator.
Ford Voltage Regulator Wiring Diagrams.
Also the drawing show a ground wire going to the battery. It is not connected either.
I purchase this car about 7yrs ago. The battery always stays charged. However with a heavy load (lights and cooling fan on), the voltage will drop below 12 at lower rpm.
I am not certain that the wire diagram in the link is correct for my setup. If it is correct and my alternator is not wired correctly, would it charge? I'm confused!
Old 06-08-2014, 08:48 PM
Tommy's Avatar
If it's worked ok as is for the past seven years, I'd cover up the loose ends with tape, keep doing what I'd been doing for the past seven years, and sleep well at night.
Tommy
Previously owned EM Cobra
Old 06-08-2014, 08:51 PM
FWB's Avatar
FWB FWB is offline
i think your fine, one of the wires is not supposed to be connected.
if you have an ammeter it will just be hanging there. Ford service manual picture below
Fred B
Old 06-09-2014, 05:24 AM
joyridin''s Avatar
I have the same problem. I realized it was due to putting on aftermarket pulleys on the crank. alternator, and water pump. The larger pulleys makes the alternator turn slower than normal at about 800 RPMs or less and it will stop charging. Give it a little gas and it jumps to 14 volts.
Old 06-09-2014, 09:39 PM
Thanks FWB.
I do not have an amp meter (voltage meter), but it looks like that wire is still not needed, based on the schematic you posted.
However it does show a ground wire. It does not have a ground wire connected to the alternator. Must be grounding through the mounting bolts. That would seem a bad thing to me.
Thoughts?
Old 06-10-2014, 06:16 AM
Maybe your car has a one wire alternator, as does mine ( an SPF ). In this case, the voltage regulator isnt used and the only connection thats needed is the one to the battery. Any other voltage regulator wires end in the wire loom. Seems odd though that the battery drops below 12. Maybe you have an alternator issue.
Old 06-10-2014, 06:38 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
On a fiberglass car, you need to ground the voltage regulator case. There is usually a ground wire which originates in the wiring harness connected to one mounting bolt. Send me some photos and I'll look them over and see what you have. What is your chassis number?
SPFWiringDiagrams@Comcast.net
Old 06-10-2014, 08:17 PM
No. The alternator has 2 wires connected to a KVR202B Ford voltage regulator mounted on top of the passenger foot box, as shown in the drawings.
Old 06-10-2014, 08:29 PM
Yes the voltage regulator case must be grounded. Voltage regulator is a KVR202B. The alternator has the square ear as pictured in the link in my first post.
After looking at the diagram that FWB posted, that is how my car is wired up. That diagram shows the alternator going to ground, but it does not specify how. The diagram in the link in my first post calls for a #10 ground wire to the battery. I have no ground wire going from the alternator to the battery (or anywhere else). I am pretty sure the case is grounding to the engine block by the mounting bolts or it would not work. My question now, is the ground wire necessary or is grounding through the mount good enough?
