February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 02-08-2015, 10:43 AM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Default How often do you grease...
How often do you grease the ball joints, drive-shaft u-joints, control arm pivots, etc? The ERA manual indicates every 12k miles, but I guess more often wouldn't hurt.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 02-08-2015, 04:16 PM
1795's Avatar
I tend to grease everything every time that I change the oil. Have been doing that for years with all of my vehicles.
Old 02-08-2015, 06:00 PM
Every 3000 miles or so. The tie rods and ball joints don't even require jacking the car up. And if you have the Moog units, they have little relief valves so you can't even overfill them. You know with your six u-joints you need to pump the grease in until you see all four of the seals clearly purge out. You can actually hear it squish out and it is impossible to over-grease them.
Old 02-09-2015, 03:57 AM
Default It depends on abuse
Kevin2 Kevin if you are hard on the car, every 1000 miles. This also depends on driving conditions like rain or track abuse. If normal driving every oil change or 3000miles which ever comes first. Also and very important, wheel bearings, repack and adjust for fronts and check hub bearing play on rears if running a Jag setup. The rest is a once a year maintainance check of the whole car with nuts and bolts being checked. There is about 12-15 grease fitting on the car with a jag setup. Unless you have a lift, pulling the tires will be needed to get a good shot at all the fittings. I use the red hitemp from Lucas for all my fittings and joints. Good luck. Rick L.
Old 02-09-2015, 06:57 AM
kevins2's Avatar
Thanks for the input. Although the ERA manual says to grease every 12,000 miles, it appears that I'm not the only one doing so more often than that.
Kevin
Old 02-09-2015, 11:03 AM
Kevin
... and don't forget the often missed zerk fitting on the back of the Smiths Speedometer Reversing unit.
Old 02-09-2015, 11:27 AM
kevins2's Avatar
I do have Smith's gauges, but not the reverse speedo. I don't recall a zerk fitting on that...
Old 02-09-2015, 11:33 AM
The reverser has one on it -- it's a great way to win a bet from a Cobra owner (with a reverse Smiths speedometer in the dash). You know, "I bet you don't even know how many zerk fittings are on your car...."
Old 02-09-2015, 04:23 PM
DanEC's Avatar
Sounds like a lawyer trick.
ERA 782 Running
