January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 05-03-2015, 08:54 AM
Cobra Make, Engine: Kirkham 427 Street, Shelby 468 FE
Originally Posted by Gaz64 View Post
The consumption of the engine is 468 x 5500 / 3456= 745 cfm.
So you do need 3 inch of height.
What is the formula that results in "3456"?
TNT
  #22 (permalink)
Old 05-03-2015, 12:46 PM
Gaz64's Avatar
Originally Posted by TNTaylor View Post
Well, I tried the R2C base plate,
http://www.summitracing.com/parts/rcp-ac10615/reviews/
with the 3" filter and it fit PERFECTLY, with at least 1/2" room to spare between the top of air cleaner and hood (remember 427 Street with NO SCOOP.) This is on a Holley 850 HP. I know this is expensive, but unlike the K&N drop bases, it works.
Pix to follow
That's great if that works for your clearance issue, now just get their 14" filter:
14 Inch High Performance Street Air Filters
Only if he does not use the extreme filter top, which has a 500cfrm flow rate of it's own.
Bill S.
Ah yes, your right Bill, but needing a minimum clearance above the bowl vents, nearly negates the use of such a low height element. Far better off getting a low drop base that flows well, as he already has done.
TNT
It is a "constant" in the engine airflow formula:
cubic inches to cubic feet= 12 x 12 x 12 =1728
x 2 (induction stroke every second revolution) = 3456
Assuming 100% VE.
Gary
  #23 (permalink)
Old 05-03-2015, 02:03 PM
Bernica's Avatar
Senior CC Premier Member
You might try staying with the 9" AF and use this 9" drop base and an Extreme top. I make the base plates and Mickmate sells the complete kit. There are several members here that are using them on some big engines. I run it on my 482 FE with a 2" AF and no problems.
MAXX Air System MAXX Air System [427 289 CSX CCX KMP ACE HT SPF] - $267.40 : Acton Custom Enterprises, Custom Metal for Cobras
