February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree31Likes
  #41 (permalink)
Old 03-23-2020, 02:01 PM
1985 CCX's Avatar
Look forward to seeing this in the first person.....
  #42 (permalink)
Old 03-23-2020, 04:40 PM
LMH's Avatar
LMH LMH is offline
What are the cutouts on the top for?
Alba gu brąth
  #43 (permalink)
Old 03-23-2020, 08:04 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Default areomotive install
this is the EXACT location it needs to be in a CSX car. it fits perfect
1985 CCX likes this.
  #44 (permalink)
Old 03-24-2020, 07:51 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
I'm not sure that would work in Jeff's car, It's the wrong colour.
  #45 (permalink)
Old 03-30-2020, 02:41 PM
cobrakiwi's Avatar
All these fuel tanks need something to hold them in place.
Today's job, get fuel tank straps ready for powder coating, these are for 427 cars.
  #46 (permalink)
Old 03-30-2020, 02:57 PM
FUNFER2's Avatar
Looking great.
For your powder coating, I have a "Group Buy" from the company Jet-Hot. If you're interested let me know.
JET HOT- Group Buy, Sale ?
Regards,
Kevin
  #47 (permalink)
Old 03-31-2020, 05:14 AM
cobrakiwi's Avatar
Looking great.
Thanks
I will keep the coating option in mind.
I have a very good working relationship with the two companies I use local for powder coating.
  #48 (permalink)
Old 03-31-2020, 08:22 AM
FUNFER2's Avatar
Ok, let me know if you want to join. 👍
Regards,
Kevin
  #49 (permalink)
Old 03-31-2020, 08:55 AM
1985 CCX's Avatar
Keep in mind that the tank Craig made for me is a 289 tank, behind the seat and not under the rear.
The cut outs are for me to get around the extra frame support with the units PU and filler neck.
Gives dead space above once full up. I'll post on the 289 link when I get started
LMH and CompClassics like this.
  #50 (permalink)
Old 06-22-2020, 10:11 PM
BigGuy's Avatar
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
Hi,
I’m looking to replace my CSX 4000 series gas tank.
Looking to go without a fuel cell as I don’t track the car.
Could you send me some info on options, prices, and time frames for your tanks?
Thanks in advance,
Jon Trimble
Jon
  #51 (permalink)
Old 06-24-2020, 03:44 PM
1985 CCX's Avatar
Originally Posted by BigGuy View Post
Hi,
Thanks in advance,
Jon Trimble
Craig is your man!
My 289 tank perfect and the 42 gallon 427 tank I bought a work of art.
I recommend highly
  #52 (permalink)
Old 03-25-2021, 08:37 AM
cobrakiwi's Avatar
Thanks Jeff.
Here we have a fuel tank just finished for a 289 street car.
1985 CCX, LMH and 1795 like this.
  #53 (permalink)
Old 03-25-2021, 01:31 PM
LMH's Avatar
LMH LMH is offline
Very nice work!
Alba gu brąth
  #54 (permalink)
Old 03-26-2021, 08:47 AM
1985 CCX's Avatar
Looks Great!
  #55 (permalink)
Old 04-10-2024, 03:56 PM
cobrakiwi's Avatar
Working on a fuel tank for one of my favorite cars, Jeff's red Hi Tech, ( soon to have a colour change) for the most part we are using the same shape of the old tank from the car.
We have added a little volume and some bead rolls to the bottom of the tank along the lines of the large original tank.
  #56 (permalink)
Old 04-10-2024, 04:06 PM
cobrakiwi's Avatar
We folded the front and rear sides, add the baffles then the top panel.
We are using the fill and pickups from the old tank as well as the fuel level sending unit, this way it should go back together with out issues.
Well that's the plan.
  #57 (permalink)
Old 04-11-2024, 03:47 PM
1985 CCX's Avatar
Look forward to installing it into HTM111.
  #58 (permalink)
Old 04-17-2024, 08:46 AM
cobrakiwi's Avatar
Drain plug added, all set to go back into the car Jeff.
1985 CCX and CompFi like this.
  #59 (permalink)
Old 04-17-2024, 09:36 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default Needs rock protection!
Hi,
Looks great. On my previous cobra I had an aluminum tank made and ran it less than a year then a rock hit it at 65 MPH and cracked the weld, aluminum is brittle. What a pain to drip gas all the way home. Then nobody would fix/ weld it as it had gas in it. So eventually a shop filled the tank with argon and welded it for me. I installed second skin on the forward side of tank:mad
Now my F5 cobra has the mustang tank and shield!
Perry.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
  #60 (permalink)
Old 04-17-2024, 09:46 AM
1985 CCX's Avatar
I look forward to installing in HTM111, will be a great addition and will serve as a great improvement in appearance/performance.
CompFi likes this.
