November 2024
Old 09-03-2017, 07:39 AM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Default Need help engine is hard to start when cold
When it's been sitting all night or all weekend. Another problem is coughing and stumblind when I get on the gas to pass.
Cheers Bryan
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 09-03-2017, 11:37 AM
Well since you didn't give much information to help people troubleshoot, I will give you an accurate answer, that may not help you much.
Your engine is running too lean. In other words, it is not getting enough fuel.
You might start with some information on, when did this start. Did it always run this way or did it used to run perfect?
Is it a carb or EFI?
What engine is it?
What carb is it or what EFI system is it?
If a carb, does it have a choke? If yes, is it Electric?
Old 09-05-2017, 10:03 AM
Texasdoc's Avatar
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
If this is a new problem and you have a carb, try blowing carb cleaner (with that tiny red straw) down thru all the air bleeds around the carb horn.
P.S. - Be careful when doing this. Lots of gas will go spraying everywhere. Cover the whole carb with a towel you are willing to trash. Wear eye protection as well.
