February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree16Likes
  #21 (permalink)
Old 12-23-2017, 02:58 PM
Default Low seats
Originally Posted by Snake2998 View Post
Mine is high backed "racing" seats - adds hugely to reducing wind buffeting at speed and hence comfort on a long drive. Have kept my "retro" seats for if I ever sell the car.
That's a big concern, there's a good reason ALL modern vehicles have headrests...One texting teen away from a broken neck.
  #22 (permalink)
Old 12-23-2017, 11:22 PM
Kobura's Avatar
Cobra Make, Engine: Backdraft RT3 #1133, Ford Racing 306
Neutral
My grill
jolsen42 and SuperWildcat like this.
  #23 (permalink)
Old 12-24-2017, 09:32 AM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
The USB phone charger in my glove box...
And the martini mixer behind the passenger seat.
TButtrick likes this.
- Robert
  #24 (permalink)
Old 12-24-2017, 09:55 PM
lovehamr's Avatar
Stolen Avitar
Wink
It "mixes" not "stirs"?
Heathen!
moore_rb likes this.
  #25 (permalink)
Old 12-27-2017, 04:49 AM
Grey 65's Avatar
Cobra Make, Engine: BDR #888, Keith Craft 408
Sticker and wider tires
315/30/18 Front
335/30/18 Rear
No reason to have power if you can't put it to the ground.
SGwick likes this.
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
  #26 (permalink)
Old 01-08-2018, 02:24 PM
t walgamuth's Avatar
315/30/18 Front
335/30/18 Rear
NIce cobra!
Grey 65 likes this.
  #27 (permalink)
Old 01-09-2018, 05:11 PM
Antny's Avatar
Cobra Make, Engine: SPO 963, 351W
Originally Posted by Kobura View Post
My grill
Details? Where did you get this grille? Is it custom made?
  #28 (permalink)
Old 01-10-2018, 11:17 AM
Kobura's Avatar
It is homemade. Aluminum bar stock from Home Depot, $500k of tools from Harbor Freight and 3 months of off/on tinkering under a tree.
  #29 (permalink)
Old 01-10-2018, 12:21 PM
Millsy's Avatar
Cobra Make, Engine: Backdraft, LS3
Tilt steering, I didnt like the location and angle of the standard steering wheel/column. Now I can put it exactly where I need it. Also the radio, I have heard many say theirs is useless and they cant hear it but mine cranks. When I want to just enjoy the sound of the car I dont put it on and when I want to hear some ripping driving tunes I use the ipod. I also had the radio wired up so I can use it when the car is off, that modification comes in handy when I stop up at the airport and sit and watch the planes land. WINTER SUCKS!!
  #30 (permalink)
Old 01-10-2018, 02:56 PM
Tom Wells's Avatar
Originally Posted by Shootnride View Post
Would love to see you do a build/project thread on the forum when you do this.
Ted
Just for you, Ted: new Project. Electric P/S - FirstCoastCobraClub
Enjoy,
Tom
  #31 (permalink)
Old 01-14-2018, 09:07 AM
RallySnake's Avatar
Over 32 years, I have changed many things. The best thing was adding gussets to the Jaguar lower suspension arms so they would not try to kill me again.
Next, was going from a high RPM drag racing cam to a milder hydraulic roller that make much more low and mid range torque. Other than that:
Backup electric fuel pump.
Comfortable seats from Classic Cobra.
Tremec TKO 5 speed trans.
3.73 gears in the Jaguar rear with limited slip.
Wilwood brakes all around.
A security system that communicates with my cell phone and tells me the car's status and exactly where it is.
Acrylic polyurethane paint (Ferrari red).
Front suspension by Classic Conversions.
Micky Thompson Sportsman S/T tires.
AFR Cylinder heads.
Classic Chambered mufflers.
Distributorless EDIS ignition from '90's Ford with Megaspark controller.
RS
  #32 (permalink)
Old 01-14-2018, 09:54 AM
Rawkkrawler's Avatar
Cobra Make, Engine: Everett Morrison
Default Fuel Pump
Originally Posted by RallySnake View Post
Backup electric fuel pump.RS
This has me thinking, since i've had this failure berore, is your bachup installed or in the toolbox just in case?
I'd like to do this, but mount permanently. I'm carbureted and run a basic inline electric fuel pump close to the tank. Can two be wired in series with a DPDT toggle to go between the two if needed? I know some MG's have done this. My need for permanent is that i won't have access for a swap out if i'm on the side of the road. I believe the pumps have basic check valves that allow the disabled pump to be a "pass through". Anyone have a best practice that can be shared? Seems like cheap insurance.
Thanks!
Mike D
Tampa Fl
  #33 (permalink)
Old 01-14-2018, 10:19 PM
eschaider's Avatar
One of these was by far the best non-traditional / non-authentic modification to my Cobra;
Ed
  #34 (permalink)
Old 01-14-2018, 10:27 PM
RallySnake's Avatar
Rawkkrawler,
Yes that's correct, both pumps are connected at the IN side and OUT side with brass "T" fittings. I am using Carter fuel pumps. Last time one failed, my son and I were coming home from Houston and in the middle of Nowhere, West Texas. We were doing about 80 on the Interstate. When it quit the engine dies and I said, "the fuel pump quit." My son says, "what are we going to do?" And I said, "push this button." I did and we cruised the rest of the 1,100 miles without a problem. That was about the 5th time one failed.
When I first wired the two pumps, I had one running or both running when I pushed the switch. Later, on a rally near Bakersfield, the car bucked to a stop with gas spraying out the top of the carburetor. After trying everything I could think of on the carb, I started thinking about the fuel pumps. I realized that the internal pressure regulator in one of the pumps had failed and I was getting too much pressure. So, I reached up under the car and pulled a wire off pump number 1. Then, everything worked fine and we finished the rally.
I was very unhappy about missing a checkpoint and losing the rally. So, I installed a pressure regulator before the carb. I also changed the wiring so that one pump or the other runs, not both. I also installed a pressure gauge and a NOS pressure switch before the carb. The NOS switch triggers a very bright light on the dash when pressure drops below 4 psi. Then, I installed the biggest fuel filter I could find between the tank and the fuel pumps. Now, the system is very reliable. The light lets me know there is a problem before the car stalls. The gauge helps troubleshoot problems. Last time the light came on, I realized that the filter was clogged. I was able to get home by swerving the car back and forth to move the crud around. It's amazing how much sand comes out of gas station pumps!
I am about to replace all of this with an EFI system. It will also have two pumps and pressure gauge and light. I will sell all of the low pressure stuff on eBay.
  #35 (permalink)
Old 01-15-2018, 01:42 AM
Rawkkrawler,
Great, thanks for the info!
Mike D
Tampa Fl
  #36 (permalink)
Old 01-15-2018, 08:37 AM
Like another member did, I made some extensions (out of plastic tubing) to extend the wing mounted rear view mirrors, also replaced the flat glass with mild convex wide angle mirrors. I'm going do a second fuel pump, and back up coil. Both have failed or overheated in the past.
Mark.
  #37 (permalink)
Old 01-15-2018, 09:28 AM
Default Heated Seats
Originally Posted by Grubby View Post
Heated seats and power source to charge my phone or GPS. Both make a Cobra much better for long road trips.
John
I would love to add this Mod to the passenger seat for the wife, as for me, well have plenty insulation...Info on installation?
Steve H
SPF 1764
  #38 (permalink)
Old 01-15-2018, 09:59 AM
Cobra Make, Engine: ERA 427
Cruise control and a cup holder!
  #39 (permalink)
Old 01-15-2018, 10:57 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Ditto With Whodeeny without the cup holder! (even though I know it's a dig!)
[IMG][/IMG]
  #40 (permalink)
Old 01-15-2018, 01:09 PM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Originally Posted by Tom Wells View Post
Thanks Tom,
This is definitely a project high on my list.
Ted
