February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree11Likes
  #21 (permalink)
Old 02-21-2019, 08:42 PM
ACHiPo's Avatar
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Originally Posted by dacobb View Post
So, my Quickjack arrived today. Missing one 2" block but otherwise everything is there.
Sent in a request to get the missing part; somewhat of a hassle as I had to look up the serial number, which requires an electron microscope to read, but OK, whatever.
The operation manual is very good.
Overall the kit looks decent. First job will be to use it on wife's car to change brake pads and rotors.
The ERA main frame is well inside the wheelbase, which is good since this thing is 69" long and won't fit between the tires.
Hope it's a good purchase and if so wish I had bought this years ago.
Which model did you end up getting?
  #22 (permalink)
Old 02-22-2019, 09:10 AM
Cobra Make, Engine: ERA #720
Is there any concern that the frame is so far inboard ther'd be no/minimal room to work in between the stands? that would pretty much relegate this to a tool for brake jobs if that's the case. I want to buy one but I wonder if the 3500 model is a better choice for a Cobra because it's a little shorter?
  #23 (permalink)
Old 02-22-2019, 09:23 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I have the 3500 model and move them as far to the outside as I can for stability.
If mine were much longer, they would not fit between the tires as I have about 3-4 in clearance.
https://youtu.be/jO8vx0-LfAc
Love mine and wish I had purchased it sooner.
  #24 (permalink)
Old 02-22-2019, 10:34 AM
dacobb's Avatar
Cobra Make, Engine: ERA 3018 - Lykins 289 H.O. SBF
the 5000 SLX.
  #25 (permalink)
Old 02-22-2019, 10:38 AM
dacobb's Avatar
The 3500 is the best choice for your Cobra, if the jack is only used for the Cobra or other lightweight vehicles.
Unfortunately, most cars weigh over 3500 lbs, so that is why I went with the 5000; I'll be using it on my daily drivers as well as the Cobra.
Based on the ERA frame, the quickjack will reside mostly under the car, so anything other than wheel/brakes/suspension work may be difficult.
I have a lift so anything related to the drivetrain can be worked on using that.
  #26 (permalink)
Old 02-22-2019, 01:44 PM
ACHiPo's Avatar
I have the 5000. It fits between the tires of my SPF (barely), but the frame members that I can use for lifting are over a foot inboard. I can still get my creeper between the QuickJacks, but it's a little claustrophobic under there. I was hoping I could position the QuickJacks further outboard on my ERA 427, but it sounds like maybe not.
  #27 (permalink)
Old 02-25-2019, 12:47 PM
pgermond's Avatar
The only issue I have with my QuickJack is being able to move around under the car. So much so, that I lower it on to jack stands. Not for the fear of the QuickJack coming down (used properly it is very secure), but to be able work on it from underneath the car. There is no way for the QuickJack to come down without weight on it so it makes it tricky getting the rails out of the way. I have to use a floor jack on the front to lift the car enough to put jack stands under it, then lower it some, and then move to the back with the floor jack and do the same thing getting it low enough so I can slide the rails out of the way after lifting and putting the stands in place.
If anyone has a better way please chime in!
A bit of a pain in a$$ compared to the Quick Lift I had but I can store the rails out of the way.
Phil
http://www.uniquecobra.com/
  #28 (permalink)
Old 02-25-2019, 02:22 PM
lnfletcher's Avatar
You must not have the correct air pressure set because they will go down without weight on them, that is the purpose of pressurizing the tubes.
If I have to do extensive work underneath, I also use it as a jack and then use jack stands.
From the Quickjack site "The small air cylinders welded to the sides of the main hydraulic cylinders act like air springs. Because the static weight of the lifting frames is minimal, the air cylinders assist lowering the frames after the vehicle's tires touch the floor, or if the lift was ever raised with no load."
and
"Inflate each air bottle cylinder between 40-50 psi. Be sure to pull the connector off quickly to minimize air loss and don’t forget to replace the dust caps as they help to retain air. The cylinders will require periodic recharging."
Mine does go down easily without weight.
cycleguy55 likes this.
  #29 (permalink)
Old 02-25-2019, 07:04 PM
pgermond's Avatar
and
Larry, That news to me. I always check/inflate the cylinders. I'll give it a try next time I use them and post the results. In the meantime - thanks!
ront49 likes this.
Phil
  #30 (permalink)
Old 02-25-2019, 07:13 PM
pgermond's Avatar
Neutral
and
Larry,
Can you provide a link to this information?
ront49 likes this.
Phil
  #31 (permalink)
Old 02-26-2019, 08:03 AM
ACHiPo's Avatar
What they said...
Check the air pressure in the assist cylinders. As I recall it needs to be 50 psi, and if the pressure is correct the QuickJack will raise and lower with no weight on it.
Last edited by ACHiPo; 02-26-2019 at 08:04 AM.. Reason: Not reading the other threads that basically said the same thing...
  #32 (permalink)
Old 02-26-2019, 08:35 AM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
I purchased and installed a Maxjax two post low rise lift to work on my car. It has 6,000 lb capacity, raises up to 4 feet, works in an 8 foot ceiling garage, and allows complete access to the underneath side of the car. It was fairly easy to install and is very secure. This lift is on sale right now at $1599 with free shipping, the normal price is $1899.
This system can be removed easily if you need it out of the way. I sit on a rolling stool when working under the car which works out well.
You have to make sure your concrete slab meets at least the minimum requirements. Mine did.
Chris
  #33 (permalink)
Old 02-26-2019, 01:58 PM
cycleguy55's Avatar
And the thread has been hijacked...
pgermond likes this.
Brian
  #34 (permalink)
Old 02-26-2019, 02:56 PM
lnfletcher's Avatar
and
Larry,
Under "What do the air cylinders do"
https://www.quickjack.com/explore/fr...#air-cylinders
  #35 (permalink)
Old 03-11-2019, 08:17 PM
Cobra Make, Engine: ERA 427sc
Originally Posted by Moriarty View Post
The lifts themselves need to be inset under the car since they are too long to fit between the front and rear wheels.
lnfletcher is right - the 3500 fits between the front and rear tires just fine.. it's that the frame is a ways inboard that winds up resulting in very little room between them. I need to remember to bias toward the outside rather than centering everything up. I leave them pushed together under the car when not in use usually.
When mine arrived, the schrader valves on both needed to be replaced for the air cylinders to hold pressure. I emailed QuickJack and they sent replacements valves right away, which were trivial to install.
  #36 (permalink)
Old 03-12-2019, 08:10 AM
ACHiPo's Avatar
I'm wondering if it would work to fabricate some cross members out of heavy-walled rectangular steel tubing that would allow the jacks to be outboard or at least between the tires?
  #37 (permalink)
Old 03-13-2019, 09:57 AM
lnfletcher's Avatar
Instead of that, just use it as a jack and put jack stands under the corners, then remove the Quickjack. This is what I do when I need a lot of room or plan on getting heavy handed on something underneath.
cycleguy55 and ACHiPo like this.
  #38 (permalink)
Old 03-13-2019, 11:24 AM
cycleguy55's Avatar
Agreed - seems like a simple solution. I have a set of 6 ton stands that extend to nearly 24" - should work fine.
Brian
