1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
12Likes
01-07-2020, 10:40 AM
Originally Posted by AdamIsAdam
Is a Superformance or ERA worth a $15-25k price difference over a well built Factory Five?
A lot of people can't visually recognize the difference between a FFR, SPF, or an ERA. To them, there would be no difference, and that's fine. To others, the difference is marked. The older FFRs have a very pronounced posterior, SPFs have their own eccentricities, ERAs have rectangular frames (instead of round ones). Some actually prefer the differences, others don't. The hips, fenders, and stances of the three cars are totally different but, if you can't see them, then it doesn't matter. If all three were parked side by side, almost anyone could spot some of the obvious differences, but not unless they were side by side. Some of the big differences that might jump out are the curves of the body itself, some of the smaller differences are things like the direction of the wipers, whether the pedals are floor mounted, the angle of the radiator, the angle of the windshield, etc. From a performance perspective, there are plenty of track quality FFR builds out there that will run circles around my FE powered ERA. But if you don't know what an FE is, or why it's important, then it doesn't matter. When it comes to performance, if the car "wows you," then that's what you want -- and it doesn't matter what's under the hood or what the car looks like. Would you pay an extra five grand for 6 pin drive hubs that you can't even see? How about an outboard braked IRS rear? An extra grand for a reverse rotating Smiths speedo? What about fitted side curtains? If you can't spot the differences, or if they don't matter to you, then you shouldn't pay for them.
01-07-2020, 10:51 AM
NY
Excellent reply. I did see, learn, figure out many of those factors. I weighed them all, plus one more not mentioned: safety inherent in the design of each car.
From what I can tell, FFR's frame in the MKIV is superior here, with front and rear crumple zones, plus that new X bracing on the side for some side impact protection. Something seemingly 100% absent on most other frames I've seen that are boxed and you basically sit atop them.
The MKIV did improve the rear end looks, as you indicated. I like it but it did take me a while to learn to spot the difference.
pin drive and true spinners are VERY cool IMO, as is the reverse sweep speedo and other touches.
As you can tell, I'm leaning towards finding a well built FFR. To me, what Superformance has going for it, is the consistency of a factory build (and ERA's built at ERA).
See where i'm leaning?
Adam
Fulfilling my lifelong dream to own a Cobra... MISSION ACCOMPLISHED!
MKIV FFR 347 cid, Levy T5, 3.55 3-link.
SOLD  Replaced by something with a Flat-6
01-07-2020, 11:03 AM
Regarding safety, there pretty much isn't any. They're like motorcycles. The biggest danger on these cars is whacking your head on the roll bar -- hard. BFT to the head is what has killed more than a couple guys on this forum. In fact, about three years ago we had a guy showing off his Cobra in the country club parking lot. He slid in to the curb, hit his head against the roll bar, and died on the way to the hospital. The car barely had a mark on it. All in the country club parking lot. If you can touch your head to the roll bar, then you'd be smart to pad it.
01-07-2020, 12:02 PM
NY
well that's really f'ed up!
I plan to put some sort of high back seat in the car, just for that reason; well, more like for whiplash. Maybe Miata seat or a race bucket. But that's what scares me most about my `64 GTO, low back seats. I sit at a red light praying the 17 year old approaching from behind is paying more attention to me than SnapChat!
Adam
01-07-2020, 12:41 PM
MI
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
OK, I'll try to not get in too much trouble.
$65k is probably high but I haven't been watching in a few years since leaving the SPF community and moving to FFR.
Price. Have you priced a new SPF? With FFRs you have time, parts, body work & paint. Both assuming new builds.
At one time the larger percentage of SPF owners installed a 351 based motor often at 400+ c.i. rather than the 289/302 based motors. There's a huge group that have 385 series 460/520 and larger motors with a bunch of FEs of various sizes.
Better than a FFR, now that's a really loaded question and I'm not going there. What I will say is that the SPF build quality is more consistent and the general parts used are consistent within the chassis number ranges.
You didn't indicate the original year of construction and chassis number, it's located on the front upper crossmember for most cars; possibly harder to find on early ones. SPF owners use this to identify the build series and it turns out to be important.
A SPF will have IRS, coilovers, leather seats, carpet in interior and trunk. Wilwood brakes were used on cars after the first few (100 or so, not sure). Again, after the first few they had pin drive & spinner wheels, 15" standard. All were factory painted and usually included top, side curtains and tonneau although these may be options on newer cars. The trunk on a SPF is larger than in the FFR.
SPF cars are heavier than FFRs, due partially design and heavier (thicker) bodies.
FFRs have many good points. Generally less expensive, lighter, easer to adapt to personal preferences, a good chassis and suspension design according to the owners choice of the components. There are many owners that build exceptional cars but skill and attention levels very.
Find a car that meets your criteria. Purchase price is just the beginning.
Jim
Former owner of SPF 1855 & 2584
Current owner (under construction) of FFR 8885
01-07-2020, 06:04 PM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
The widow's car is listed with a broker here:
https://www.webeautos.com/details-19...d-ny69972.html
They're asking $65k. I'm looking to spend less.
Can you tell by the pics if it's hydraulic clutch? Is that master cylinder on the firewall for brakes or clutch? I'm not familiar with these cars enough to know.
$65k seems to be about right for a big block(427) car, even more if it is an all aluminum shelby motor. but $65k for a small black car seems a bit high. That being said. It is a nice car. if your budget allows try to get the SPF vs the other cars you mentioned. Just a few days ago a guy was wanting a VERY nice ERA car here for about the same price... If I were in the market for a Cobra I would JUMP at that car. I have owned an ERA can for 18 years, zero issues and the clutch was perfect.
01-07-2020, 06:35 PM
NY
Mike,
I saw those cars, love that shade of red for sure.
I'm looking to spend much closer to $40k than $65k. But I don't want to buy "wrong," so to speak. That's why I was saying, is a $40k FFR a better deal than a $60+ SPF?
I'll keep looking. I LOVE getting the advice, so keep it coming, and THANKS!
Adam
01-07-2020, 07:08 PM
I have not seen a lot of nice $40k cars. Every now and then it does happen, so finding one is not impossible... but damn close to it.
01-08-2020, 12:04 PM
SC
Cobra Make, Engine: FFR MkII
Thanks. Yea, this makes sense. It's funny, because I was trying to compare the overall quality and driving feel of the Superformance to the Factory Five to see if I thought it was worth the difference in cost.
The car drove fine, felt underwhelming in terms of power surprisingly, even though it ran well (no clutch slipping or anything like that, just not "Cobra" strong). The clutch was stiff obviously. The interior under the dash was a little bit of a wiring mess, the panel above my knees was loose. The car didn't start without a jump even though it was cranking. And then took a while to fill the carb bowls and fire. But once on, ran ok, especially for a car that sat so long.
Oh but the wiper WASHER worked! LOL. That was funny when the broker hit that switch by accident. Everything worked as far as I could tell.
Overall, I didn't see it being worth $65k vs the $45k or so I can spend for a similar FFR. So that's sort of my dilemma. Is a Superformance or ERA worth a $15-25k price difference over a well built Factory Five? That's over 40% more money to buy. How will depreciation affect both? Enough to get back (or not lose) the purchase price? Meaning, if I compare spending $65k vs $45k car in 5 years, what's the ROI on both?
I'm looking at one FFR locally that was fully built by the FFR factory, so it's professionally built and that can be documented. If I got it for $45k, is that a smarter buy than a $65k Superformance?
Again, I am fully aware that this is a hobby and not my 401k. We are all on the same page there. I just want to make the above comparison and welcome input from those who have been in this market longer than I.
Thanks!
FFR owner here - and I seriously doubt documentation of a FFR built car. It just doesn't happen. Not even a "roller" - much less a "driver".
01-08-2020, 12:19 PM
NY
It's true. They built the car for a charity auction. After seeing the car, I spoke with Tony Zullo at FFR personally to confirm this, since he is the one who actually built the car. He said they build it in the factory first, then take it apart, ship it to TN to put it back together again on the golf course with the FedEx pilots, to be auctioned off for charity. (I presume they shipped it via FedEx LOL)
I have tons of proof, but how about this for proof:
https://youtu.be/xWj7I4Q3ReU
At 1:40 you can see the car in question.
Adam
01-08-2020, 12:28 PM
NY
BTW, how do you like your FFR? Any tips/suggestions for me as I shop for one?
Adam
01-08-2020, 12:34 PM
SC
Ask FFR what VIN # is on the MSO. FFR does not meet Federal Standards to market "automobiles".
But - have it your way. Don't mean to be argumentative on the issue, just wanted you to not be hoodwinked by an unscrupulous seller.
01-08-2020, 12:43 PM
SC
I love it - have 30,000 miles on it in four years. Pushing right at 400 hp out of a stroked (347) 302.
I was at Daytona Continental race the first time Shelby showed up with Cobras! Only took me 50 years to get mine.
I am available to discuss anytime - shoot me a PM!
01-08-2020, 12:45 PM
NY
I understand and do not take it to be argumentative. I verified the VIN when I called.
My guess is that they sent/sold the kit to the charity, then the volunteers assembled it and auctioned it off. The person who won the auction brought it back to NY where he drove it for 2 years without ever titling it. I think he either had a dealer plate or just threw on other plates illegally. But the consigning dealer who has it now said he would handle titling it properly in the name of the new buyer. That would, of course, be a condition of sale.
The problem is, the guy really wants $50k for it. (even more). But I think it's worth low to mid 40's.
The car is brand new basically. It's got 1,400 miles, the paint is perfect. But it's a low end build in terms of the parts: Blueprint crate 306cid/370hp motor. TKO500, 4 link 3.55 Moser rear. 18" wheels/tires with track tires. ALL parts were brand new. No heater, wipers or other options.
So what's that worth?
Adam
01-08-2020, 01:33 PM
Ca
With that drive train, $40k at the most. The FFR’s that actually sell for $50k plus will have IRS, 500+ hp, a TKO 600, and custom paint and lots of upgrades.
This Build is a straight forward entry level kit.
My first FFR had a 302. Fun car but two years later I moved up to a SPF with 550 hp. Much better street car. More solid and much faster.
Happy hunting.
Jim
01-08-2020, 04:58 PM
Adam, here's another tip. On the street, if your car has an honest 400 horsepower, it's the same as if it had 600. Of course, the race track is another story.
01-08-2020, 06:10 PM
NJ
Cobra Make, Engine: BDR #1604, VMS 427
Thanks for the insight. I'm learning as I go. But I'm also not going to wait forever like the owner of this car did. He only got 200 miles on the car before he died.
I am a quick study. And I'm hoping/relying on the kindness of forum friends to help me through the buying process. And the ownership thereafter.
I hope this note comes across the right way. I'm asking for help and very appreciative of any I get.
I was trying to use this Superformance as my benchmark. It drove worse than the FFR I drove, as I said.
Tom,
Yes, exactly what I was looking for, a car that's been sitting and developing leaks, etc. I've seen it before as well. I'm not sure exactly how long it's been since the owner died before the nice widow finally decided to sell, but it's a while. She actually said she just had the car gone over to get it ready for sale. I didn't get into what was done, but yes, I agree, when you buy a car that's been sitting, it can be just as expensive to bring up to good working order as a car with high mileage.
12 years is a long time for a car to sit.....
01-08-2020, 06:52 PM
NY
Yup, 100% agreed! Most folks feel anything over 400 is hard to use on the street. My new GT350 is 526 and weighs 3,800lbs, with serious rubber, traction controls, etc, and I feel I can't come anywhere close to using it all to a point where it's frustrating to drive. But yes, on the track that car COMES ALIVE in a big way!
Agreed. And they want top dollar. I'll pass on that one.
Adam
01-08-2020, 07:11 PM
NJ
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Re-visiting the thread
After re-reading the thread I want chime in with. The original SPF car discussed I wouldn't even consider. Budget engine, sitting too long and over priced by a lot. The only FF's I would own would be one I built myself or one that was built by someone I was completely familiar with by reputation and verified they actually constructed the car. That leaves you with the rest. Disregard the Kirkhams...rich persons toy. Make a the best deal you can for the remaining options. Everyone thinks their car is worth more than it really is and they find that out when they try to sell it. Cobra Country consistently represents the best market values. Vanguard Motors will show you some nice overpriced cars. There are some great values out there.
Fred
