January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 04-11-2020, 07:22 AM
DanEC's Avatar
A lot of people swear by those Motive pressure bleeders as the thing to use. I've always been a little worried about pressuring up a master cylinder even to just 6 or 8 PSI for fear DOT 3 or 4 fluid might somehow spew out on nice paint if the seal was broken. But never heard of it happening. But it does seem like a fool proof way of getting around all the problems of air leaking past bleeding screws and so forth.
ERA 782 Running
  #22 (permalink)
Old 04-13-2020, 11:44 PM
Originally Posted by kevins2 View Post
Anyone use a pressure bleeder? Seems like it would accomplish the same thing - a quick, one person bleed. Of course, your car would have to have a reservoir that the bleeder would connect to, probably wouldn't work with the 3 cans.
Each can powers a system. Pressurize each one and bleed that system. Think of it as bleeding 3 reservoirs and their respective cylinder(s).
Tom
  #23 (permalink)
Old 04-14-2020, 06:14 AM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Thanks Tom, I was thinking the lids on the cans were likely a non-standard size (or thread size) that the pressure bleeder wouldn't screw on to. I believe most of the pressure bleeders come with two or three caps to accommodate different sizes so, if one of them fit, it should work fine. My main point was that this seems like a simpler solution than the self-bleeders and I'm considering getting one.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
  #24 (permalink)
Old 04-15-2020, 01:22 PM
cycleguy55's Avatar
Speed bleeders are great. Once you get the right size and install them it's smooth sailing from there.
Highly recommend them.
Brian
  #25 (permalink)
Old 04-15-2020, 05:39 PM
Cobra Make, Engine: ERA FIA #2064 BOSS 302 CSX2047 sold
Forget the fancy pumps and speed bleeders. Forget using two people. Just
use a Mayonnaise jar and a short piece of clear plastic hose and do it by yourself.
Use "search" to find this thread: "Best approach to bleeding the brakes." See
Patricks entries on the mayonnaise jar method. It works!
  #26 (permalink)
Old 04-15-2020, 09:44 PM
t walgamuth's Avatar
Thanks very much!
