February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree7Likes
  #21 (permalink)
Old 08-03-2020, 10:38 AM
cycleguy55's Avatar
Originally Posted by FredG View Post
Today was the first nice day in a while. I have the front of the cooler blocked off with insulated metal duct tape. Temp is pushing 90 outside. Took a nice long ride. Oil temp on gauge reads constantly at 140-150 degrees. I took several readings with a laser temp reader and engine running.
Remote oil filter- 205 degrees
oil cooler input line - 190 degrees
oil cooler output line - 175 degrees
oil pan next to sending unit - 185 degrees.
This is a new autometer gauge and sending unit.
Old autometer gauge and sending unit never got above 150 degrees also.
Thoughts.......
Thanks
Fred
I trust the sending unit is in the oil pan with the 'probe' fully immersed in oil.
Did you install it with thread sealing tape or thread sealer of some kind? If so, it may not be properly grounded.
Brian
  #22 (permalink)
Old 08-03-2020, 11:03 AM
FredG's Avatar
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Good Point
The directions from Autometer call for using a telfon thread sealant which is what I used. There is a reducer adapter that is screwed into the welded portion that holds the sender. Shorting the sender sends the needle to the highest reading so the gauge is working. Going to check it with an ohm meter next to see what kind of continuity there is between a good ground and the body of the sender. I noticed on the Autometer site there is something called a short sweep sending unit which is what I have. Just got off the phone with them and they confirmed the using a teflon thread sealer as well as using an ohmmeter to test the grounding. Onward....
Thanks
Fred
cycleguy55 likes this.
  #23 (permalink)
Old 08-04-2020, 10:07 AM
On those senders a poor connection, poor ground can cause the cold reading (high resistance=low temp. Or its a bad sensor. Since its a new sensor and gauge I'd lean to what Cycleguy mentioned.
https://www.autometer.com/sensor_specs
PS: over-torquing the center stud can really screw them up permanently. Should be snug enough to prevent the eyelet from swiveling only.
  #24 (permalink)
Old 08-04-2020, 11:49 AM
FredG's Avatar
Default Done with it for now.
Spoke to Autometer on the phone and they suggested a continuity test from the body of the sending unit to the frame. I already did that and it was fine. Grounded the gauge connection on the sender and the gauge went to max so the gauge is fine. As long as I know the oil is over 200 degrees in the pan I am not going to worry about it till I change the oil and pull the sender. Thanks for the chart. Going to compare laser oil pan reading to sender ohm reading next time I take the car out.
Fred
