January 2025
26 27 28 29 30 31
Like Tree14Likes
  #21 (permalink)
Old 01-13-2022, 03:34 AM
Cobra Make, Engine: Superformance aluminum 427FE
Originally Posted by Blas View Post
You might want to add a protective sleeve of some kind where the wires enter the original light boxes. Chafing of wire insulation on the boxes could cause a problem down the road. The readily available split plastic sleeves might be just the thing to make the new wiring disappear.
Blas
Either that or just remove the old light box....it really isn't needed at all in this install.
  #22 (permalink)
Old 01-13-2022, 02:29 PM
cycleguy55's Avatar
Originally Posted by strictlypersonl View Post
The 3-wire tail lights are original, the 4-wire units are proprietary to Superformance. Original cars used a relay on the firewall to merge the brake and signal inputs. Some trailer relays can do the same thing.
This unit from U-Haul would work - it converts separate turn (L,R) and stop signal input into combined left stop/turn and right stop/turn. Should work for all vehicles originally equipped with incandescent bulbs.
https://www.uhaul.com/MovingSupplies...Flat/?id=13684
Brian
