January 2025
26 27 28 29 30 31
Like Tree41Likes
  #61 (permalink)
Old 07-31-2023, 06:55 PM
john4337's Avatar
Cobra Make, Engine: Factory Five Racing, 306, E cam
Default More progress
Time for another update. I decided i wanted a more finished look than a spray in finish, so I took a run at headliner.
I primed the inside and scuffed with 150 grit to (hopefully) give the adhesive something to grab
For material I used this, perforated textured vinyl with 1/8 foam backing to help hide my uneven fiberglass work. I ordered 3 yards.
In it goes. I ended up using 3 large sections, and a smaller piece at the windscreen. Lots of compound curves in there.
This is the windscreen section. I used a length of rope glued in to create a bead and to get the curves I needed.
Next the windows go back in. They didn’t go back anywhere as easily as they came out.
I apparently changed the shape of the back window opening enough to cause issues, so I made a pattern and trimmed the window some.
Once it was back in, I tucked the material behind the window gaskets, and made some beading to cover the seams, ending up with this.
kitcarbp, Alfa02 and rustyrims like this.
  #62 (permalink)
Old 08-01-2023, 06:04 PM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Very nice work on the headliner. When I was completing my hardtop I decided to use a black headliner foam material and cut it from a single piece, the goal was no seams. I painstakingly applied glue in sections , clamped and stretched ….repeat. Now note that I have never ever made a headliner before this attempt. My gallery shows the results. It turn out just average since I was unable to avoid wrinkles in the back corners using 1 piece. I’m convinced my process was flawed. Thankfully when the top is on since it’s black , and in a shadow , the wrinkles are hard to see. But I know they’re there. So I can appreciate this craftsmanship. Nice. Oh and my rear window install left my fingers bruised and battered but it’s been in now for 3 years and hasn’t blown out with 80 mph highway driving. Yet.
john4337 likes this.
"...some assembly required, ages 8 and up...... well that took longer than expected......
  #63 (permalink)
Old 08-02-2023, 09:45 AM
john4337's Avatar
Neutral
Red face
Thanks, I was planning on a one piece headliner too, but just too many compound inside curves to not have a bunch of wrinkles, so 3 pieces it is. And I agree, those windows were a chore, tool most of 2 days to get them in, including lots of breaks to rest the fingers. Tough job.
  #64 (permalink)
Old 08-02-2023, 04:45 PM
john4337's Avatar
Default Getting closer
Sawdust and rustyrims like this.
  #65 (permalink)
Old 08-04-2023, 01:13 PM
john4337's Avatar
Default Final Post
All the mounting hardware is on, so I guess this is the final post on this. Thanks to everyone for all the kind words, encouragement and for following along.
Sawdust, Lenni-65 and rustyrims like this.
  #66 (permalink)
Old 08-04-2023, 11:59 PM
Thumbs up Nice!!
Congrats on seeing it through to fruition! Great job!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
  #67 (permalink)
Old 08-05-2023, 09:58 AM
indianamoon's Avatar
Cobra Make, Engine: B & B 289
Very nice job, impressive work!!
  #68 (permalink)
Old 08-05-2023, 10:09 AM
jknich's Avatar
Excellent craftsmanship !
Jim Nichols
