April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 01-15-2003, 09:17 PM
Gordon Claunch's Avatar
Default Oil temp sender
Hi, Can someone tell me the best place to put the oil temp sender, I had it with the oil pressure sender, by the filter, the oil pressure worked every now and then and the temp did not work at all. I plumbed up the oil pressure all by itself at the same place and now it works fine, but I need to hook up the temp sender now and I am confused as where to go with it, any ideas?? Why could'nt they just share a place???
Gordon Claunch
If you can't afford what you want to buy, pick up a book and learn how to make it.
Old 01-16-2003, 04:00 AM
Gordon,
In the oil pan, below normal oil level. That way gives the best indication of the heat generated by the bearings.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
