December 2024
  #21 (permalink)
Old 07-16-2003, 06:04 PM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Way to go Chip. Sounds like you are nearing Nirvana.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
  #22 (permalink)
Old 07-16-2003, 06:56 PM
She just cranked!!!!! It was the wire from the solenoid to the starter. Just put a new one on that I had around and it cranked!!! Now lets see if it starts! cb
  #23 (permalink)
Old 07-16-2003, 07:11 PM
Itis running!!!! Has not since May! Have to pur her back together now-not much. Seems was that one bad wire!
THANK YOU ALL! cb
  #24 (permalink)
Old 07-16-2003, 09:54 PM
The final analysis: It was the "perfect storm" series of causes: Weak/dead/old battery, BAD charger that showed the battery had a full charge and a suspect cable from the solenoid to the starter.
Should have tested the battery, but charger showed it fully charged. Really suspected a dead ground in the wiring from the battery to the starter, as everyone suggested. When I could kick the starter by touching a jumoer ffm the pos of the bat directly to the starter motor, I started working backward from the starter. Also hooked up the old solenoid again.
Thank you all! cb
  #25 (permalink)
Old 07-17-2003, 06:53 PM
Send a message via AIM to cobramandave
Chris,
Glad You got her running. Have a great time in Alabama. Are you going to Kershaw.
David,
  #26 (permalink)
Old 07-17-2003, 09:51 PM
Not going to Keshaw this time but may do the Atlanta Motor Speedway CARZ event comming up. Plan to do the Alabama ShelbyAuto Club lapping 8/9 at the Talledega Gran Prix Track (lttle Taledega) at the Oxford-Anniston exit. Good tight track. Atlanta Historics in Sept: come on up! Like to stay close to home: cheaper, and we now have s many tracks close! Chip (aka "chris")
