1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
07-14-2003, 07:16 PM
Spf Oil Temp?????
I was wondering what the upper limit for Oil TEMP for a 460/535. I have a SPF so what would it be in "C"...
SPF 1618
460, 552hp
+ Pro Shot Fogger system
(250hp shot)
802hp total
titanium\black stripes
07-14-2003, 07:57 PM
CA
Cobra Make, Engine: Multiply resurrected Superformance #584 (silver), 351W : 437 lb-ft, 445 HP
Your oil has recommended limits
I will try and recall this from memory (dangerous) and say that the upper limit for my SB with Red Line synthetic was ~100 C on the track. Usually, on the road, it rarely got above 60C. The calculation is: F (degrees) =9/5 X C(degrees) +32 degrees. So 100C is 212 F
Hope this helps! The BB guys can better shed light on this than I.
Randy Klein who has lots more posts on this site than are listed...and wants y'all to drive safely.
07-14-2003, 08:50 PM
WA
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
The coolant can run up to 220 F
So, the oil can get even hotter. Mine gets upwards of 230+ in heavy traffic conditions. But it may run cooler soon when I change to water and water wetter only. I also plan to enhance my oil cooler system, possibly with an electric fan/ forced air unit.
Ford 385 series run hot, so it seems, and so I have been told.. ?
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
07-15-2003, 08:16 AM
Cal
Motor oil should be kept below 230 F
07-15-2003, 08:24 AM
Member of the north
Cobra Make, Engine: A Cobra
Bud Moore recommends 220 F ( I think, age seems to effect the memory )
07-15-2003, 12:11 PM
nj
Cobra Make, Engine: SPF #623 460/4x2
Ive read that the bearings run about 15 to 20 degrees hotter than the oil....and the melting point for the bearings are around 290 degrees?? So, anything more than 115c is pushing it.
Does anyone know more than this?
Dane
07-15-2003, 01:00 PM
Oil Temp
There seems to be a lot of ideas about this. I talked to Eric at Performance engineering and he said Oil Temp can run up to 120C without a problem. I saw 105C, he said no issues there at all.
SPF 1618
460, 552hp
(250hp shot)
802hp total
07-15-2003, 02:34 PM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Mine runs at 180 F. I think the sensor is after the cooler.
Bob
07-18-2003, 10:53 AM
Quoting from the Instruction Sheet supplied by Ford Racing for my 460/535 crate, part no. 6007-B460
"An engine oil cooler such as the SVO M-6642-A101 is highly recommended - -"
" Oil temperature should be maintained in the 220-270 degree F range"
Actual street experience on my car - on hot Florida days in traffic, oil temp stays around 200-210 F. Once I get on open road and get some air through the cooler, it comes way down.
A good rule of thumb to convert "C" to "F" is: Double the number and add 15. This appies pretty close in the ranges of oil and water operating temps.
Lynn
"Cool Toys use 93 Octane"
