February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 12-10-2003, 08:27 PM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Default dual quads
I am needing carburation for my new motor,I had decided on a single 4bbl,mostly for cost,but I love the look and torque of two 4's
I have found a nice complete original set up,med riser ford intake,c5af carbs,linkage and fuel log,nice condition,is 1500 a good price ?
thanks again,,Tim
Tk
"this whole Adult thing just isnt working for me "
Old 12-10-2003, 08:57 PM
KobraKarl's Avatar
Tim,
IF....those are truly original 2x4 carbs,..And the manifold is clean and free of heliciols etc..that is not a bad deal..
give me the list # off the air horn and I can tell you if they are correct.
KK
Foolish consistancy is the hobgoblin of tiny minds
Old 12-11-2003, 01:16 AM
Sal Gerace's Avatar
Club Cobra Member
Cobra Make, Engine: CSX4300, C5AE-H, Toploader
Holley is making the vintage carbs with the correct numbers on the airhorns. You can get them from Branda's or Carl's Ford parts for about $1000.00 for the pair, brand spanking new and correct! Just a suggestion because I am looking also and any original carbs I have found need a rebuild and replating. About $300.00 to $400.00 each!! You also have to make sure the manifold was not ported or any major repairs. Cracks and stripped threads are very common on aluminum intakes. ust my 2 cents, Sal.
Old 12-11-2003, 10:38 AM
Cobra Make, Engine: Factory Five, 302 EFI, #3358
Keep in mind a couple of rather important issues. First, dual quads are not going to give you much HP return on your investment. A single 4 brl carb gives you plenty of air. Second, keeping dual quads properly syncronized and tuned is a pain.
I think if you want more HP, you can get that for your money through many other better means.
Old 12-11-2003, 10:47 AM
Club Cobra Member
Send a message via AIM to K.Wilson
Tim,
The medium riser dual quad intakes ae hard to find. I have been looking for a C7AE or the C7ZX MR Intake for a year without much luck.
Keith
Old 12-11-2003, 12:49 PM
sierramadre45's Avatar
Cobra Make, Engine: Superformance 1710, Sunset Red/Titanium Stripe, 428 FE with dual quads
If they're set up correctly, there's no more maintenance than a single carb. They don't add much horsepower and they don't do much for your gas mileage, but they look and sound fantastic.
Old 12-11-2003, 02:34 PM
Karl,,
The carb numbers are c5ae-Bu and BT
I realize what you guys are saying,I od dissagree on the maintenence,once there right,there right,I have a dual quad set up now on my other motor,I dont think i would go to a single four for 100 Hp,,just the awesome looks and sound,I realize i can get more HP for my money by other means,but by that rationale a vette would be the way to go,,Nothing says " I'm Bad" like 2 yours,,except maybe webers,,
thanks for the help guys,,Tim
Tk
Old 12-11-2003, 09:06 PM
KobraKarl's Avatar
Tim,
2x4 carbs require a little more time to dial in (not much)and require almost nothing there after...
also there is a significant hp increase with 2x4's up to 40....
The # I need are the LIST # on the air horn , you gave me the ford part #.......(which are the correct ones ,)...but the LIST # will confirm.
Oh yea ....they also look ...bad ass.
KK
Old 12-11-2003, 09:37 PM
Cobra Make, Engine: NAF replica, 351W, about 420 HP
What size are/were the dual quads in CFM?
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
Old 12-13-2003, 11:01 AM
the set up i am talking about is dual plane, a couple have told me I need a single plane intake for a light car.I am tending to believe that since there is more than usable torque on the low end any way.
Whats the census ? 454 fe,cam profile peaks in the 65 to 66 hundred rpm range,6800 redline,would I benefit greatly by single plane ?
This set up has no intake cast number,only fomoco ,and the firing order,who ever said it was right,for maybe another hundred bucks i can get a new blue thunder and new carbs,it isnt like my car is "matching numbers " any way,,still on the fence though,,Tim
Tk
Old 12-13-2003, 11:24 AM
KobraKarl's Avatar
Tim,
That set up is getting pretty rare......the lack of a part # identifies the manifold as original , not otc......Torque is king .....keep the dual plane........you have the exact setup i'm running ....i wouldnt trade it for any thing else,........now what are those LIST #'s
KK
Old 12-13-2003, 11:38 AM
Karl,I emailed for those numbers,according to my ford book the bu carb is 780,,makes me think either the set is mismatched,or way too much,,
I will let you know when I get the numbers,thank you again for the help,,
Dove sells matched 725 cfm carbs for 750 per pair,that dosent sound bad if I have to put together my own setup,,
Tim
Tk
Old 12-13-2003, 02:59 PM
Karl,
does 3410 and 3411 do any thing ? Tim
Tk
Old 12-13-2003, 05:13 PM
KobraKarl's Avatar
Yep,.....Perfecto....
Highly sought after genuine article.....used in the mid 60's...my set is the 2652's used in the early 60's......if you dont buy them , pass me along to them.
KK
KK
Old 12-13-2003, 05:16 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Default Too much carb...
Yes. but do you really want to run 1450cfm? Are you running 11-12:1??? at WOT or driving at Lemans? I would go with the Holley 450's or 600's max.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 12-13-2003, 05:22 PM
Thanks Karl,,
btw,,I am running two 715's now on my high rise,,they work great,the high rise looses some crispness on the low end,,but pulls like a freight train all the way to shift points and beyond,,Tim
Tk
Old 12-13-2003, 06:09 PM
KobraKarl's Avatar
Micheal ,
I thought the 3410/11 combo were the 590 or 650 cfm...??
KK
Old 12-13-2003, 09:20 PM
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
KobraKarl,
I hope you guys don't mind my adding to this thread.
I have the same dual-quad setup you have (This set up has no intake cast number,only fomoco ,and the firing order....) and I don't know what Ford vehicle it came from. Do you have any idea what year(s) and model(s) of cars that Ford used this configuration? I'm just curious and would like to be able to explain it to friends.
Thanks!
*** OF GREAT WORTH *** And JESUS asked again, “The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the ’57 Thunderbird, the ’63 Stingray, the XKE, and bought the dark blue 427 Cobra.” The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
Old 12-13-2003, 09:51 PM
KobraKarl's Avatar
CCompt,
We dont own this thread........If you have the midriser, it came on some fairlane's , galaxy's...and I think even a few commets and Falcons, If you have the low riser it would be Fairlanes and Galaxy's.........The later versions that were in the Mustangs had a part # cast in the manifold.
KK
Old 12-19-2003, 01:11 PM
Karl,
Not sure if your still subscribed to this,but just an update.
I ended up getting the dual 4 set up,i should have it in my hands tomorrow,it seems to be the same intake you have from looking at your pics,and i got the original air cleaner also, I know it is not cobra correct,but I may run it,I think it will be cool ,I was able to negotiate a bit better price than the 1500 and a customer is picking it up in St Louis to bring it here,if for any reason I decide not to use it i will let you know,I sure do like those dove air gap intakes,,lol thanks for the help,,Tim
Tk
