February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 02-08-2004, 11:26 AM
ENTDOC's Avatar
Default cooling question
When my 351c warms up to about 190 degrees the purge outlet on the Moroso T filler starts to purge foamy coolant into the overflow tank.I would have thought by now all of the air in the system should have been purged.It settles down after a while and cooling has never been affected(175-180 when driving,190-210 idling).I do not seem to have a leak anywhere but this is concerning.I have a 16 lb cap on the T filler.Any thoughts? thanks;chuck
Old 02-08-2004, 04:46 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
As water heats up, it expands. As it cools down, it contracts.
Some cooling systems leave air space at the top of the radiator to allow for this expansion & contraction. Others, like your Cobra & mine have a coolant recovery system so the hot coolant can puke into the recovery tank when hot, and suck back into the engine when cool. Mine "Breathes" about 1/2 qt in and out of the engine. Am using a Stant 7# cap to avoid pressure build up that might push a hose off one of the crossover tubes. Thermostat is 180 deg year round.
Old 02-08-2004, 07:02 PM
ENTDOC's Avatar
Thanks Jack,I guess as long as it does not overheat I should not worry. chuck
Old 02-08-2004, 07:34 PM
KobraKarl's Avatar
Chuck ,
If the feed tube dosnt go below the coolant level in your recovery tank when cold , you could be pulling in air as you cycle from hot to cold.....
KK
Foolish consistancy is the hobgoblin of tiny minds
Old 02-09-2004, 08:37 PM
Cobra Make, Engine: NAF replica, 351W, about 420 HP
The "foamy" part of 'Doc's statement seems to have me worried...now I am not a mechanic, but would not having foam in the coolant indicate a contamination problem? I am just theorizing here...
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
