January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 02-26-2004, 06:50 PM
mgilbert's Avatar
Cobra Make, Engine: la exotics 289 5speed 9in. 270hp 295tq w/ g-tech
bruce, no i do not want to pull manifold it's not broke HA HA . could the motor mounts be hiding them slightly? any idea about threaded holes in block. i wish i work in an auto shop & not a print shop
  #22 (permalink)
Old 02-26-2004, 06:56 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
The threaded hole on the left side is for the factory clutch Z-bar pivot.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
  #23 (permalink)
Old 02-26-2004, 07:09 PM
mgilbert's Avatar
bruce, i'm going to find these sob-ing #'s. those #'s have me P.O.ed. their i feel better now. Thanks again
  #24 (permalink)
Old 02-26-2004, 07:36 PM
I have a 289 and a 302 block at the shop and I will check for the location in the morning. Sorry my memory is not working.
Bruce Edwards
  #25 (permalink)
Old 02-26-2004, 09:13 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
I have a 289 hi-po in my car, the casting numbers on the block are just above the starter ---very hard to see---took me awhile to finally locate them---in frustration I finally rubbed a piece of chalk in the area and lo and behold there were the the numbers.
FWIW hope it helps.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
  #26 (permalink)
Old 02-26-2004, 10:28 PM
mgilbert's Avatar
hello G.R. are the numbers on a little ear or pad that protudes off the block or on the block directly. thanx for your reply mark gilbert
  #27 (permalink)
Old 02-26-2004, 10:34 PM
G.R.'s Avatar
Post
Mark they were just below the protrusion above the starter, rather small and hard to see
  #28 (permalink)
Old 02-26-2004, 10:41 PM
mgilbert's Avatar
G.R. later i'll give it another try. thank you, thank all of you catch you all later
  #29 (permalink)
Old 02-27-2004, 07:42 AM
Mark,
Right rear side. You may have to remove the starter to see it.
Bruce Edwards
