February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 03-21-2004, 07:09 PM
jschiller's Avatar
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
Default Dual oil filters...
Do any of you use dual oil filters? How are they connected, one filter feeds the other one? Do you use the same filter on both, or does the setup require a "coarse" and a "fine" filter to work properly.
Lastly, heve you ever cut open the filters to see what was trapped by each.
Very curious to know if they have any advantage over a single filter. Especially with the frequent oil changes most do.
John
Old 03-21-2004, 07:15 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Send a message to Bill Malone (bmalone)...he ran them in his Contemporary
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 03-21-2004, 08:27 PM
hcollado's Avatar
Cobra Make, Engine: Everett/Morrison- Boss 302 Stroked W/351W heads and a whole bunch of ponies
Thumbs up
Definitely overkill. You have to be sure to drill out the passage so that they run in parallel and not in a series. And yes, you use the same size filters. Look in my gallery and you will see my set up.
What you are really doing is providing more filtering area thru the same in and out ports without restricting the flow or pressure.
Hector Collado
Everyday is a Holiday ... every meal is a banquet.
Old 03-21-2004, 09:01 PM
aumoore's Avatar
Cobra Make, Engine: Hunter 427, 5.0 (302)
I have dual filters and other than the crappy seal due to poorly machined filter mount it works great. I guess you get more filtering area and the extra filter gives close to another quart of oil capacity.
One filter shoudl be fine for most applications but I do run some road course running and I wanted as much oil as possible. I have now put in a Canton 9quart road race oil pan.
Click here for DSCC website
Old 03-21-2004, 09:14 PM
jschiller's Avatar
aumoore--
With a 9 quart pan and 2 oil filters (and a cooler?) an oil change must cost as much as a full gas tank does these days
John
