1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
05-04-2006, 09:57 AM
mickey thompson sportsman s/r tires
just checking to see if anyone is running the new mickey thompson sportsman s/r radial on there superformance cobra ? specifically the 26x10.00r x 15lt front and the 26x12.00r x 15lt rear any clearance problems?Thanks Jeff
10-16-2007, 11:38 AM
UT
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Every report I have seen on our roadsters says they are fantastic!
Considering a set for my son's car.
10-25-2007, 06:54 AM
AZ
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Hey Guys, I'm running a set of MT S/R radials on my Hurricane. 295's on the back and 255's on the front on Vintage pin drivewheels. No clearance problems and they stick like crazy. Look great and perform very well.
Best Regards, Bill
10-25-2007, 07:25 AM
IL
Cobra Make, Engine: CRII 351W/408 Stroker
Anybody have a good source for these tires?
Thanks,
Ed
10-25-2007, 07:48 AM
PA
Bagram AF Afghanistan
10-25-2007, 08:10 AM
IL
Originally Posted by fsstnotch
Thanks!
Ed
10-25-2007, 10:46 AM
PA
Cobra Make, Engine: Unique 427SC/331/5 forward
Anybody driven them in the rain, or on wet roads?
Not that this is a habit, but do occasionally get caught in the rain, and good to know how they react.
10-31-2007, 07:35 PM
MA
Cobra Make, Engine: Butler with home-rebuilt 393 Cleveland stroker(Ya---ikes!)
Bill,
What are the rim-widths you're using? I have a set of 10" and 8" wide Vintiques (?) AND also a set of 12" and 10" wide Centerlines. My Butler cobra is set up for absolutely huge tire widths (up to 17" in the rear), but am considering exactly what you're running on your Hurricane. Unfortunately, I didn't see the M/T S/Rs designated in the 295 and 255 sizes you stipulated. DO you have part numbers on these?
One cobra owner I know runs M/T Sportsman tires---they're non-radial, but he says they're great for drifitng---really predictable. I'd be interested in hearing your opinion(s) about that type, also.
Thanks for any input,
Freddie
11-01-2007, 12:10 PM
Renegade Nuns on Wheels
Oh
I emailed Mickey Thompson S/R radial asking how they handle and what the treadwear was. They say they handle 'good' (compared to what I don't know) and they did not have a treadwear number. They said they where a 'hard' compound and should last 10-20k. So, not to hard!
11-01-2007, 03:52 PM
AZ
Fred,
I purchased #6653 26x10.00R15/LT/M/TSPT/SR for the fronts, and #6654 26x12.00R15/LT/M/T/SPT/SR FOR THE REARS.
I have Vintage pin drive wheels 10" wide in the front and 12", they are fine as for clearence in the wheel wells and no problem turning. The tires seem to work great and grips well and slides smoothly if you get on it in the lower gears. Although I'm a novice as far as racing goes, the car (Hurricane) handles great and steers straight at high speeds 110 mph and feels very stable.
So far I'm happy with the tires, by the way the reason I bought them over Goodyear and BFG is their high speed rating (100mph) and the Flame tread design. I think they are available through any tire shop by special order.
Best of luck, Bill
11-01-2007, 04:22 PM
any photos of your car? Thanks Jeff
11-01-2007, 10:48 PM
Junior Member
CA
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
Tom
11-01-2007, 10:56 PM
CA
New shoes look good Tom! I'm not going to be able to keep up with you on Hwy 17.
Doug
11-02-2007, 05:52 AM
mo
hey guys look at the sidwall of the tire does it give a treadwear rating???they look nice!!
11-02-2007, 08:00 AM
MA
Hi Tom!
Looks like you repainted the car! Wow!
I do have a question about your description of the tires: when you said they were "smaller than the BFGs", did you mean outside diameter or tread-width?
Freddie
11-02-2007, 08:26 AM
Banned
CA
Fred, I can attest from having tried the exact front tires that he is referencing outside diameter. They will look more squatty (if that's the right description?!?) than what we are used to running and the shoulders are a little more square than your typical GY/BFG/Dunlop. The height actually swayed my ultimate decision and I went with drag radials on all four corners as a result. The S/R's are a good looking tire though, I'll give them that, and with the recent limiting decisions (no Avids, no Goodyears, etc.) I can see a lot of Cobra enthusiasts leaning toward these as a cost effective alternative to an Avon or even a set of drag radials.
-Dean
11-02-2007, 08:29 AM
Junior Member
CA
Doug, Thanks
WildBill3, No treadwear rating on the tires.
Freddie, Where ya been? Na, old paint. Just keep it clean. Tread width is smaller. About 1/2". Are you driving yours yet?
Tom
11-02-2007, 08:38 AM
Tires look great!
11-04-2007, 07:21 AM
MA
Tom,
Yes---for a while----and then I decided to redo the paint, which was chipping off the too-hard primer. I'm seriously thinking about black----also (of course) new tires. I have some "new" Centerline rims which look sorta like the old Lamborghinis (!?) with the deep lug holes. They're fully 12" and 10" and can take mega tires. Hence the questions.
As for relaunch of the completed car-----it's sorta looking like February. Still futzing with the stroker--more or less pay as I go. My builder is a really good guy and lets me do lots of the work (that would be the not too critical work, that is---ar-ar-ar-ar-ar),
That stuff you sent on the roll bar angle put me miles ahead.
More later.
Freddie
11-04-2007, 10:32 AM
Junior Member
CA
Freddie,
I am not acquainted with centerline wheels. The old Anson Sprint Mags I had were held on with caped nuts and washers. This means no conical lug nut registering in a counter sunk wheel stud hole. My problem was the washer holding the wheel on would allow the wheel to be mounted slightly different each mounting resulting in out of balance. I discovered this by marking the hub and wheel then removing the wheel and installing it 180 degrees from the hub mark. All of a sudden my unbalanced wheel becomes balanced. Just the weight of the wheel while tightening the nuts would shift the wheel enough to change the balance at each install. I spent 7 years and hundreds of $$ trying to get a good balance that was never possible. My new wheels are prefect.
My old wheels were 8.5 in front and 10 in the rear. Now 7.5 in front and 9.5 in the rear. The fronts actually look good now because they were sticking out beyond the wheel well too much. The rears now are too much in from the wheel well. But everything will stay as is because I’m generally happy with it all.
Black is a great color. You can’t do wrong with that. Good luck with everything. Give me a ring if you have any questions.
Tom
