| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
08-22-2007, 06:19 PM
FL
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Hydraulic Throw out bearing
Well,
BDR 559 arrived today (yeaaaaaaa). Getting ready to drop the 410W and TKO 600 when I realized that the quicktime bellhousing doesn't accomodate a slave and I will need to run a hydraulic T/O bearing.
It has been recommeded that I use the McLeod but I'm not 100% sure which one I need?
1. MCL-1400-30?
or
2. MCL-1364?
Also is there a spacer (MCL-1439) needed for iether?
Thanks,
Mark
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
08-22-2007, 06:56 PM
Backdraft Racing Dealer
CT
We use Quicktime bellhousings and external slave cylinders on every car we sell now. A great combo... no need to go with a hydro t/o bearing.
08-22-2007, 06:58 PM
ca
Just call them, you will need to know the distant from the flywheel face to where the trans bolt to the bell housing
Mike Z
08-22-2007, 07:04 PM
FL
Jay,
Thanks for your help.
Reg had told me that it wouldn't.. I will explore in more detail in the morning...
BDR 559
SBF 410
HP= Enough!!
08-22-2007, 08:19 PM
WA
Cobra Make, Engine: Superformance Brock Coupe
Might be as good idea to check out the Tilton unit...easier to adjust. Badger
08-22-2007, 08:25 PM
Banned
Absolutely go with external slave cylinder, just ask JAMO.
My shaft mounted McLeod failed before I even put the car down from the lift. Then I went with the external slave. No problems and better feel, IMO.
Good luck.
08-23-2007, 12:00 AM
Super Moderator
CA
Good luck.
Yeah...just ask him!
Assolutely the most vile POS PIA concept ever conceived.
Jamo
08-22-2007, 08:44 PM
CT
Looks like it fits here
08-22-2007, 09:13 PM
ca
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Do not use a hydraulic Throw out bearing......gigantic PIA!
Dave
08-23-2007, 05:38 AM
OK
Hummm,
Mine has worked well for years. Just a pia to get it bled out.
Clois
"Let's roll"
"Be part of Something Good
08-23-2007, 05:52 AM
AL
Here's my two cents on HTOB.
Pros
- Don't need space for a slave cylinder
- Don't need to buy/fabricate a bracket to hold the slave cylinder
Cons
- If you don't get the spacing just right, it'll leak.
- If you don't install a stop block to prevent over extension, it'll leak.
- If you don't secure the hydraulic lines inside the bell housing and they touch the spinning assembly, it'll leak.
- (This is the big one) If it leaks, you'll have to pull the entire transmission and likely replace the hydraulic fluid soaked clutch to fix it.
After dropping my transimssion several times, I threw away my McLeod HTOB and installed a clutch fork and slave cylinder on a bracket I made. I haven't had another problem with my clutch operation.
Tommy
Previously owned EM Cobra
08-23-2007, 06:30 AM
Banned
clarification, they are both hydraulic, one is external and one is on the input shaft. . . .
08-23-2007, 06:50 AM
FL
Jay,
I can't make out your picture very well... What bracket are you using to mount the standard BDR slave to the bell housing?
BDR 559
SBF 410
HP= Enough!!
08-23-2007, 07:11 AM
Canadian Gashole
QC
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I installed a Tilton HTOB in my Lakewood scattershield 7 years ago. I followed the instructions for installing and adjusting it, never had a problem. Bleeding it was no problem as I installed a 2' length of SS flexible hose and put the bleeder on the end of it. No need to even go under the car to bleed it.
Wayne
Don't get caught dead, sitting on your seat belt.
08-23-2007, 10:12 AM
Tx
Wayne
The internal htob get a bad name because they were not setup properly, I get calls all the time about guys having a leak and 100% of the time it is due to the installation. Before I will sell them a new seal kit, I make them check there distances again and the bearing is generally to far away from the fingers of the clutch. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
08-23-2007, 11:48 AM
Canadian Gashole
QC
None of my friends or car buddies had any experience with the HTOB so I had to do it completely on my own. I read, then re-read the instructions before installing it. It has worked perfectly from day one. It appears that many people don't read or else don't follow the installation instructions properly.
Wayne
08-23-2007, 08:28 AM
NJ
I have had my Tilton HTB in for 25k miles. I have never had a problem.
Roscoe
Roscoe
08-23-2007, 10:15 AM
NJ
Usually it's the fault of the installer. They forget to put a pedal stop or adjust it wrong and it over strokes the bearing, popping the seal. My Tilton has been working flawlessly for 25k miles.
Roscoe
Roscoe
08-23-2007, 12:21 PM
NJ
Real men don't need instruction!
Roscoe
Roscoe
08-23-2007, 12:42 PM
GER
Cobra Make, Engine: Shamrock ,350 chevy, jag axles
Friend of mine installed a bearing of a mercedes van (don't know which); after that, it worked flawless.
Gernod
This is a mans world, but what would it be without a cobra!
