March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #41 (permalink)
Old 10-29-2008, 05:08 PM
Don Don is offline
David:
Can you reply with the part numbers and quantities that you ordered ?
..........thanks
Don
  #42 (permalink)
Old 10-29-2008, 07:38 PM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by Don View Post
David:
..........thanks
Don
1 728 kit
2 9703
2 9706
2 9184
2 91489
1 1768
1 4213
I ordered extra stuff because it is going to be custom and I want it to look good, in reality, you could just go with the 728 kit.
I am also putting a K+N stubstack on the carb, and a holley heatshield under the carb
I am also going to order from pegasus tomorrow 12 ft of the black neoprene 4 inch hose. This is going to do outside the wheelwells to the brake cooling duct holes both sides
  #43 (permalink)
Old 11-01-2008, 10:16 PM
Ant Ant is offline
Default Air Plenum
Originally Posted by vettestr View Post
Took me a while to find some photos but here is 1 view.
vettestr,
I am interested in your air pleunum, I have had a look at Spectre's website for something like that, are those available, it looks good and appears to have more area over the float bowls etc?
I am wondering with an almost 700bhp engine in my car, that an air plenum maybe restrictive, but if the sizing is done correctly with the cold air bonus, it should work, the only way will be to compare lap times or dyno I guess!
A J. Newton
The 1960's rocked!
  #44 (permalink)
Old 11-01-2008, 11:01 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
AJ<
Do a Internet search on turbo carb hats or try Ebay, same search as they have tons of options.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
  #45 (permalink)
Old 11-02-2008, 10:20 AM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I currently have inline dual Holleys on a Dove Tunnelwedge intake. The car is an older EM replica. The S&H air cleaners are trimmed a little to fit up against the hood. I've thought about another hood scoop. A larger scoop to accomadate an oval aircleaner, problem the scoop would dump rain water directly onto the distributer. A cowl induction scoop would have to be large enough for that oval aircleaner but would need to look somewhat appropreiate. A system like this would solve a lot of my problems. A single hose and hat to each carb and somehow ducted so the filters were out in the cars nose in front of the radiater.
Mike H
  #46 (permalink)
Old 11-02-2008, 11:57 AM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile Dyno?
Originally Posted by Ant View Post
vettestr,
Dyno wont give the answer Ant as it cannot replicate the dynamic airflow into the plenum /airbox, going have to rely on EGT, Plug readings, Lap Times, etc for this one. Which means the cars going to have to be on the track!!!
Jac Mac
  #47 (permalink)
Old 11-07-2008, 01:44 PM
Ant Ant is offline
Default Dyno?
Jacmac,
You are right about track time, what ever way I look at it especially with trying to obtain cold or ambient air, driving the car is the only way of experimenting!
From a restriction point of view (stationary vehicle) the dyno may indicate general suction of a direct ducted tubular filter system, compared to the present 2 ply 14" X 3.5" K&N, incidently that air filter had "no power loss" on the dyno compared to no air filter at all.
I was intending on having air filters in front of radiator, which isnt really a cold air system.
If I could bring back the air filter/ducting to level with front of carb or back more, it would make a huge difference to the size of the front of the scoop, but would make no difference to driver visual height, due to the RamSC having a steeper bonnet angle. My issues are only aesthetic
A J. Newton
The 1960's rocked!
  #48 (permalink)
Old 11-12-2008, 07:57 AM
Don Don is offline
I sent an inquiry to Spectre regarding performance improvements using the Muscle Car Cold Air Intake, reply below:
" Through our testing, we have found gains of 1.5 - 2.0% for every 10deg or so the intake temperature is reduced. The latest car that we have tested on the dyno with a Muscle Car Cold Air Intake was a 1970 Chevrolet Camaro with a 383CI. The kit gave us close to a 20HP difference, when compared to the stock setup sucking in hot under hood air. We do not have any published data to send you, as of yet. We are still going over all of our numbers and trying to get them in a readable format, which we can release to the public. I hope that this answers your questions. If you have any further questions or comments, then please feel free to shoot me an email at georgel@spectreperformance.com or give me a call at (800)-821-4868 ext 336 "
Thanks
George
George Luna ~ Spectre Performance
(909).673.9800 ext.336
1720 S. Carlos Ave ~ Ontario CA 91761
  #49 (permalink)
Old 11-12-2008, 02:58 PM
Thanks
George
I received all my parts and I am less than thrilled to be honest..I really don't know how I am going to make this thing work at all.I guess a lot of things are going to need to change. Hood clearance will be no issue, however valve cover clearance, spark plug wire routing, 4' cold air routing in the engine bay, heater core supply and return water lines will be! I will probably need to run a spacer under the carb to bring the hole thing up. I am also not happy with the chrome quality at all, little nicks and sanding scratches chromed over..CHEAP LOOKING. When I ordered it last week they had no polished version, just chrome in the low profile. I was on the site yesterday and the day before and now they are offering an polished version, I called them wanting to trade for what I originally wanted, he said I would have to return it to Summitt, blah blah blah. They have now taken it off the website because it is not even priced yet and should not have been up there yet.
The guy I had spoke with gave me a lot of wrong information and measurements. It has a 12.5x 3" element, not a 13.5 as he had said, it also measure 22.5 overall width, not 24". The airbox is not sealed at the bottom, it has an 1/8 inch gap all the way around which is going to let some heat in, they could have definately done a better job here! Also, the element is a unique size that is only available thru them. I am still trying to figure out the drop down at the valve cover area. This would be a lot easier if I just ripped it apart, but I am not ready to rip the car apart yet, still some nice cruising weather.
I did the math on the cfm on their filter and I am getting 706cfm, they are claiming 900+, I questioned his formula, turns out , their is no formula, their numbers are coming from a flow bench on the whole air box. I don't know how it could possibly flow more that the element is capaqble of flowing
Hey Don, you are not that far from me, if you would like to come down to Southbury to check it out , you would be more than welcome!
Regards...Dave
  #50 (permalink)
Old 11-13-2008, 08:24 AM
Don Don is offline
Dave....thanks for the invitation, if I pursue I will be in contact. In my case, I had also been considering the installation for the AMX, which would have a great deal of space under the hood.
I have had some experience with Summit, their return policy, at least for me, was liberal.
With the reply from Spectre, would appear the product announcement article in Kit Car Builder was lifted directly from the Spectre press release
  #51 (permalink)
Old 11-13-2008, 08:55 AM
Your welcome...that thing would be right at home under the hood of a AMX
  #52 (permalink)
Old 11-13-2008, 10:18 AM
Cobra Make, Engine: Look-a-like cobra POS
Kinda reminds me of a '64 Thunderbolt.
B. Ewing
  #53 (permalink)
Old 12-11-2008, 11:49 PM
Well I finally got to taking off the turkey pan and carb.
This first fitting was rough, but I think it will work, will need some massaging for sure. I had to put it on diagonally, actually looks better IMO. I have a 1/2inch spacer/ heat shield underneath, this whole thing will need to come up another 1/2 inch. I will see if I can post a pic or two.
Well I guess not, it says 39 kb is the max size, I cant get it that small, 75 kb was the smallest. If anybody would like pics, PM me your email and I will send them.
Dave
