February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #141 (permalink)
Old 02-15-2008, 12:48 PM
wtm442's Avatar
Beam Me Up Scottie
The only way I've found to get to those clubs is via the HOME page and then select FORUMS and then scroll down to the clubs.
Warren
  #142 (permalink)
Old 02-15-2008, 12:50 PM
wtm442's Avatar
Beam Me Up Scottie
Originally Posted by Ron61 View Post
Warren,
I don't ever go to that page but I just tried it and I don't have to scroll down. Maybe try setting your resolution a little higher.
Sorry Ron, I ain't going to change my screen resolution.
Warren
  #143 (permalink)
Old 02-15-2008, 12:57 PM
Ron61's Avatar
Post
Warren,
Here is my Home Page at the default resolution.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
  #144 (permalink)
Old 02-15-2008, 03:57 PM
wtm442's Avatar
Beam Me Up Scottie
I'm only missing then bottom 3 club links, but a pop open box should not disappear during a scoll drown on a wheel mouse. It did not act that way before the big crash, so I'd like to see Brent's reply. Of course, I know what Jamo's response would be!
Warren
  #145 (permalink)
Old 02-16-2008, 06:10 AM
Ron61's Avatar
Your mouse is sick. Replace it with a turtle.
Nothing on mind vanishes when I scroll down. Of course I am not using IE 7. Just the old standard IR 6 that works.
Ron 61
Ronnie Widener
  #146 (permalink)
Old 02-16-2008, 09:52 AM
Brent Mills's Avatar
Administrator
The script to make that thing work is ancient. With the software updates, something went a bit wrong. It used to be that the menu would float and remain visible at the top of the page at all times. A couple years ago, that stopped working and now it won't work at all in some areas of the forum.
I'll see if I can find another script that will work.
  #147 (permalink)
Old 02-16-2008, 12:11 PM
wtm442's Avatar
Beam Me Up Scottie
Put that LAST on your list of priorities.
Warren
  #148 (permalink)
Old 02-18-2008, 07:09 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
PHP has encountered an Access Violation at 028AAA08
  #149 (permalink)
Old 02-23-2008, 08:42 PM
Madmiles442's Avatar
Question
I just got this one:
PHP has encountered an Unhandled Exception Code -2147483645 at 028B30E1
MadMiles442
  #150 (permalink)
Old 03-02-2008, 04:43 PM
Got the Bug's Avatar
Brent or Ron - Wanted to give you a heads up that I'm not seeing the option to IM. I went into my folder and it appeared as though my mailbox was full, so I cleared out all of the IMs in my folders. I don't see the link on the "quick links" either.
Thanks.
Doug
  #151 (permalink)
Old 03-02-2008, 07:46 PM
Calbullet's Avatar
PHP has encountered an Access Violation at 03363770
  #152 (permalink)
Old 03-02-2008, 07:52 PM
wtm442's Avatar
Beam Me Up Scottie
Warren
  #153 (permalink)
Old 03-02-2008, 09:01 PM
Looks like in the welcome block on the upper right side right above quick links and log out is missing PM information. When I try to even look up my PM information it says that the page cant be found.
Terry
  #154 (permalink)
Old 03-03-2008, 02:54 AM
Ron61's Avatar
Post
Terry,
It is working for me this morning. I ran into a couple of odd things yesterday that failed but figured Brent might be working on the servers. I just waited a while and they started working again. My signature line doesn't' work but I can take that out as it isn't important enough to have him worry about it.
Ron 61
Ronnie Widener
  #155 (permalink)
Old 03-03-2008, 07:00 AM
Ron,
It is working this morning for me also
Thank you, Terry
  #156 (permalink)
Old 03-03-2008, 08:32 AM
PM is working for me again as well.
Doug
  #157 (permalink)
Old 03-05-2008, 06:57 PM
jshel1's Avatar
I am unable to see the current poll... the poll box is filled with the following text:
The block type Latest Poll
doesn't seem to exist.
Please check your
includes/blocks/poll script.
Anyone else having problem with the poll?
2011 TCC President
JSHEL1 on the Web
  #158 (permalink)
Old 03-05-2008, 07:10 PM
computerworks's Avatar
Please check your
Thanks...that is a known problem. The panel that is to display the latest poll is misconfigured.
It'll get fixed.
  #159 (permalink)
Old 03-05-2008, 07:19 PM
jshel1's Avatar
sorry to report a known problem... I should have read through the whole thread.
2011 TCC President
JSHEL1 on the Web
  #160 (permalink)
Old 03-05-2008, 07:52 PM
No problem, John...good to keep hearing whatever glitches are seen by our users. Thanks.
