January 2025
26 27 28 29 30 31
Old 02-23-2008, 04:10 PM
Full Throttle Al's Avatar
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
Default Berg 60mm IDA Carb
Gene Berg is now offering a 60mm Weber IDA carb, anyone tried one of these? My motor needs a set of these carbs!
Here is a stock Weber 48mm next to a Berg 58mm carb:
Alan Sorkey
Shreveport, LA
CSWX4083, The "Cammer Cobra"
Old 02-23-2008, 06:08 PM
Default Where's the manifold Al
Al I know of one guy running 58mm Olbergs There is a real problem with the throttle bodies sealing to the intake manifold. There is only about 1/8" in some spots of seal surface. 550+ cube SOHC motor, those carbs should be just right.Lets see about 800HP, going to need a stronger Jag rearend. Quickchange rearend here we come. Rick L.
