February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 03-20-2009, 12:51 AM
Tonkin NZ's Avatar
Cobra Make, Engine: Indigo Superformance MkIII. Ford 460, TKO600
Thanks Night Enforcer, good point I will look at that. Luckily no other damage ecept a stuffed brake pad and bent caliper bracket. Still $800 labour to fix.
Madmaxx, thanks for the compliment. New Zealanders are just a bit different ;-)Thanks also for the other things to check, I have had the 'wheel rubbing squeak' so I hope that sorts it out.
For details on SPF2828 - click here
  #22 (permalink)
Old 06-15-2009, 01:13 PM
Cobra Make, Engine: Superformance #2846, Roush 427R
I just had exactly the same problem on my spf2846 yesterday. Checked other side front and found them just finger loose. None of them had lock tite. Are these guys nuts?? I thought I was lucky I didn't get killed because I was only going 20 at the time. Stephen in Reno installed my engine, but roller came from inventory at Lance Stander's place in irvine, CA
Rablaw
  #23 (permalink)
Old 06-15-2009, 02:20 PM
Got the Bug's Avatar
Rablaw
Did you give Lance a heads-up to let him know about the problem?
Doug
  #24 (permalink)
Old 06-15-2009, 09:04 PM
SCOF posted a service bulletin that owners of chassis 2800+ should check the front and rear brake caliper bolts. Locktite may not have been applied to the bolts at the factory.
http://performanceunlimited.com/scof/
Doug
