January 2025
26 27 28 29 30 31
Old 04-08-2009, 02:54 AM
boxhead's Avatar
Default Mobra - Hemi powered Cobra by Shelby?
Can anyone shed light on this?
http://www.xs4all.nl/~luukb/mobra.html
I am guessing it is rubbish but you never know?
Cruising in 5th
Old 04-08-2009, 05:23 AM
Default There are a couple of 426 old hemis in cobras
boxhead A couple of guys have already done this about 8-10 years ago. Feeling was, that the hemi was easier and stronger engineered before aftermarket blocks came to the table. Cheaper than buying FE parts also.
Old 04-08-2009, 05:55 AM
Almost anything is.
Old 04-08-2009, 06:05 AM
Senile Club Cobra Member
"And in 1967 when Ford introduced the GT40"
I love these stories, always told by a "friend who was there" or some such tripe.
And all 7 will soon show up on eBay!
rick@autoventureusa.net
Old 04-08-2009, 06:32 AM
lovehamr's Avatar
Stolen Avitar
Or Barrett Jackson; remember Hemis have a way of magically appearing there.
Steve
Old 04-08-2009, 02:17 PM
joyridin''s Avatar
Was this the Hemi used in those Cobras?
Dual overhead cam Hemi
A 426 dual-overhead cam Hemi was actually produced - two of them, in fact, and both were made in 1964. The DOHC Hemis were made to counter Ford's response to the 1964 426 Hemi, the 427 SOHC, but when NASCAR ruled against Ford's engine, there was no need for the overhead-cam Hemi.
Neither of the DOHC Hemis were ever placed in a car; one was destroyed, the other moved to the Kansas City area. (source: Muscle Car Review. Thanks, Stéphanie Dumas.) Recently, famed engine builder Larry Shepard told us that he has the A-925 cylinder head and other related parts, purchased from the late Dan Napp.
An article by Tom Shaw in Mopar Muscle went into more detail. The DOHC Hemi was project A-925, and it would need to be much more powerful than Ford's SOHC 427, but still rugged enough for racing - and able to conform to NASCAR's rules. Two possibilities were considered, according to Shaw - one using two cams positioned between the heads, in the "valley;" four valves on each cylinder were operated by lifters, pushrods, and lifters. This expensive setup was an unused contingency plan. Nearly as ambitious was an engine with aluminum heads, dual overhead cams, and, again, four valves per cylinder, with pent-roof chambers. (Chrysler had been working with four valve per cylinder engines for a never-completed Indy run in 1963.)
The dual-plane intake manifold had eight runners per side (Chrysler was into efficient and innovative intakes) and made of magnesium - but designed for a single four-barrel carburetor, as required by NASCAR.
The cams were driven by a cog belt, using external cog wheels at the front of the heads. Because the cams were directly above the valves, valvetrain mass was low, so the engine could rev high - a 7,000 rpm redline was specified, high for the era.
Shaw wrote that no DOHC Hemi ran under its own power; they were driven by an electric motor to check the valvegear. Research stopped in 1964 when NASCAR banned the SOHC 427 and Chrysler's own race Hemi. One DOHC Hemi still exists.
DOHC Hemi Update:
Jon Field wrote that there was a third (at least) DOHC Hemi made — and that he owns it, a 301 cid aluminum-block-and-head engine with twin cams, two cam covers on each head (the plugs are between them), hydraulic tappets, brass valve seats, and four Weber two-barrel carbs (165 cfm each). He says the oil pan holds 10.6 quarts, and that the engine has stainless steel headers, and an aluminum intake; it is apparently functional and runs on regular gas. We don't have any information on where it came from and whether it's a Chrysler effort or an aftermarket modification.
Old 04-09-2009, 06:05 AM
fastraxsg's Avatar
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
In the 2007 Snake Torque calendar put out by the Cobraclub in the UK, there was a really nice red replica Cobra with a hemi under the hood. I am still trying to find the picture but was very nice. Maybe TonyD or some of the guys on the other side of the pond will know where to find the photos. I believe they are posted on that forum too. It isn't one of the Mobras though...
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".......from Will Rogers
