1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
04-21-2009, 10:09 PM
AB
Cobra Make, Engine: west Coast Cobra FRP 460, Tremec 5 sp, Ford 9" rear
427 to 460 dimension difference
Hi all you extremely knowledgable engine guy's. What is the dimensional difference between a 427 and 460 ? I am mostly wondering if a 460 is much taller than a 427 as I have no clearance between my air cleaner and hood scoop. Any info apprciated.
Thanks
Brent
Brent
Get in,buckle up,hang on and scream all you want cause nobody's gonna hear you over the sidepipes!
04-21-2009, 10:23 PM
MD
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
460 Height
Brent, I have a '08 Ford Racing Catalog that shows the 460 crate engine height of 26 inches from bottom of front sump to the carb mounting pad when using their Ford intake as supplied. The heights will vary depending on which intake and what type of sump folks are running.
Hopefully the FE crowd will pipe in the heights they know of to give a ball park comparison
"...some assembly required, ages 8 and up...... well that took longer than expected......
04-21-2009, 10:30 PM
AB
Hey Bill
It sounds like we spend too much time on the computer. No wonder I don't get anything done. Thanks for that info. Now we just need 427 specs.
Brent
Brent
04-21-2009, 11:47 PM
CA
04-22-2009, 10:20 AM
Ca.
garage10...if my memory serves me corectly (and it probably dosent) i read an article that said the 460 was an inch longer ,an inch wider,and an inch taller and weighed a hundred pounds more but i dont know how true that is?????????????
04-22-2009, 07:26 PM
NC
Cobra Make, Engine: Factory 5 mk4 445 FE
Get that 460.. throw on these heads and valve covers, get a taller hood.. and you sir , will indeed be the MAN
http://www.jonkaaseracingengines.com...bbf-heads.html
04-22-2009, 10:05 PM
VIC
ERA Replicas has a nice diagram
link: http://www.erareplicas.com/427/engpro.htm
LoBelly
04-22-2009, 10:18 PM
AB
RACERAL
I suppose I would be the man! unfortunately my finances are more like a boy these day's.
Thanks for the info everyone.
Brent
Brent
