December 2024
Old 08-27-2009, 08:44 AM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Default Clutch stop ??????
Hey.
Is anyone running a stop on their clutch pedal ??
I had my master cylinder go out after 2000 miles.
Would build a slight pressure, then go to the floor
with the clutch not working.
Replaced it last night and I now have a properly
operating clutch.
Running a Wilwood remote master cylinder with a
CNC pull slave cylinder and a three finger clutch
cover.
Thanks in advance,
BC
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 08-27-2009, 10:50 AM
snakebittexan's Avatar
Cobra Make, Engine: BackDraft, Keith Craft 408; 1967 GT500CR
Default Same problem
Funny you should ask. I have a Backdraft with the third clutch slave cylender in thirty days going in this week. No clutch stop is in the back of mind as being an issue. Will back off on how far I depress it and see if my problem goes away--not sure--just a thought.
Old 08-27-2009, 11:13 AM
There's no inherent reason that more stroke than necessary will "break" a master cylinder unless there's corrosion past the normal stroke. Most masters are built to allow bottoming out without damage.
Look for misalignment of the rod going into the cylinder (which will wear the side of the bore) or water or other contamination in the fluid. Always use DOT type 3 or 4 fluid in the system. I like Castrol GT LMA fluid for the best compatibility.
Old 08-27-2009, 12:11 PM
Double Venom's Avatar
Well..... ,
Wildwood Tech. Dept. and Tiltons tech Dept. both state as little as 3/16"s in to far will blow the seals on either one of the above mentioned cylinders. I have an adjustable stop on all manuals, whether Cobra or Street Rod. When your clutch is new; just press the pedal in as far as it needs to be to shift/engage synchros easily, measure how far off the floor the pedal is and this is where your adjustable "STOP" should start.
As the clutch wears in/out just drop your adjusting rod a little. No reason 50,000 miles can't be be an easy range to get to before putting in a new M/C.
DV
