1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
08-28-2009, 08:55 AM
Ma
Cobra Make, Engine: Kirkham 592
I have edelbrock heads on a 482 FE. Which sparks plugs?
I was wondering for a moderate build which brands guys are having luck with. I rather go with a traditional plug instead of the platnium stuff
08-28-2009, 09:12 AM
PA
actually i prefer the autolite platinums for my 468......KCR supplied NGKs with the build, but i changed over to the autolites when i needed a different heat range.
fred
08-28-2009, 09:18 AM
CA
I've used all of these without problems
NGK BK5RE
Autolite 3926
Champion RC12YC
08-28-2009, 09:25 AM
On a "moderate build," with an MSD Box, coil, and distributor, any of the three plugs that xlr8or listed will last longer than you will. Personally, I use the Champions that were third on his list.
08-28-2009, 10:49 AM
I use Autolites
ng8264723 Platinum plug are not reccomended when running MSD setup in the car. 6AL box and HVHC coil. Running a coil is OK. I run 3924 plugs in my 482 motor with .045" gap. Run clean and good startup. Rick L.
08-28-2009, 11:05 AM
Ma
I have no MSD setup. I don't think it necessary. Another area for probems. For now I have the Mallory unilte distrisbitor and an MSD coil.
08-28-2009, 11:47 AM
Stolen Avitar
GA
You're running a unilight but worried about problems with an MSD? "necessary"? Nope, but it can sure make life with a fire-breather much easier.
Steve
08-28-2009, 12:05 PM
Ca.
ng8264723.......dont worry i run the same distributer and coil as you do and i've had no problems on my mild built FE and i also strongley recomend the Autolite 3926 plugs.
08-28-2009, 01:58 PM
I`ve got a 482 and run either AR 3923 or AR 3924 with a gap of .045 ". I just tried the 3924`s and they were too hot for my engine .
08-28-2009, 02:26 PM
ca
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Ditto on the Champion RC12YC.
Dave
08-28-2009, 04:41 PM
Accel 416.
Chas.
