Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 03-14-2010, 03:48 PM
Cobra Make, Engine: A&C
Default Nose insert
Been busy. Friend has a factory five. Convinced I need a a nose insert. Its .032 aluminium. It will butt up against the radiator with bulb seal. Should be a good look.
Old 03-14-2010, 06:00 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
I also put aluminumin the nose area, then put in an aluminum shelf over the oil cooler.
Makes me want to pull the engine someday and do the entire engine compartment.
Jim
OhioCobraClub.com
Old 03-14-2010, 06:06 PM
PNJSNAK's Avatar
Club Cobra Member
I meant to add a pic of my cars nose area.
Jim
OhioCobraClub.com
Old 03-14-2010, 09:50 PM
"Q"'s Avatar
"Q" "Q" is offline
Cobra Make, Engine: 383 Stroked and Blown Chevy powered Cobra
Same idea done a bit different and in stainless steel.
Old 03-15-2010, 03:14 PM
I like those grills.
rc
Old 03-15-2010, 03:45 PM
FUNFER2's Avatar
How did you guys form the panel to conform to the oval fish mouth shape ?
Looks great.
Regards,
Kevin
Old 03-15-2010, 04:28 PM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Looks good!
Mine was made by a friend of mine, we decided to put a little lip on the forward end of it where it mates up to the body. I too have a rubber seal on it where it meets the radiator.
Juggernaut
Old 03-15-2010, 05:35 PM
To get it to fit. I started out with a cardboard template. Using tin snips I cut to shape. .032 is fairly flexible to roll into a circle to get in and out through the nose. I plan on pop riveting it in place.
Old 03-16-2010, 06:10 PM
I got the back end trimmed. Added some bulb seal around the back end. Good tight fit.
More to come.
Old 03-16-2010, 11:13 PM
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
Good job!
Let us know if you notice any difference in temps before and after.
Thanks for sharing.
John
Old 04-08-2010, 08:44 AM
A little bit more grill work. To fill the lower oil cooler inlet. Got this idea from the factory five forum.
Old 08-12-2010, 01:56 PM
Hi rdc767, can you tell us what you used for the rubber gasket around the aluminum against the radiator?
Thanks,
Old 08-13-2010, 11:50 AM
I found it.
https://factoryfiveparts.com/product...6&cat=0&page=1
my friend built a factory five and had a bunch of extra. Works great. Has metal strip built in the the rubber that grabs the aluminum. I bet you can find it cheaper.
I guess it comes with the cobra and daytona kits. If you know a builder he has some extra.
Old 08-15-2010, 09:33 AM
http://www.youtube.com/watch?v=fEQPl...=youtube_gdata
