Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree2Likes
Old 12-09-2016, 04:15 AM
Cobra Make, Engine: Antique & Collectible Autos, Inc.
Default Progress
Progress.....new wheels and tires......body on frame.....doors on....
Old 12-09-2016, 04:41 AM
1795's Avatar
Long time coming, but it looks like you are getting close. Good luck! Hopefully it will be on the rad when the nice weather rolls around again.
Old 12-09-2016, 09:38 AM
Cobra Make, Engine: Antique & Collectibles, Forte 427 SB, TKO 600
Any major "pains in the butt" you`ve come across so far?
Past posts in this sub forum have made mention that mounting the doors is a real P.I.T.A.
Old 12-09-2016, 07:49 PM
Default Doors
The only issue I had was the need to remove some material on the inside of the drivers side door lip otherwise it would rub on the front fender when the door is opened up all the way. I covered the fender with 3 layers of plastic tape to protect it while I sanded the back of the door lip with 80, 120, 220, 400 and then 600 grit wet paper. I did this while holding the door almost opened completely. I took extra care to make sure I didn't sand any area that would be visible when the door is closed. Other than that I am very pleased with the A & C kit.
