Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 09-17-2010, 06:08 AM
Cobra Make, Engine: Contemporary Cobra
Default keeping hot air out of the footbox
I get a lot of hot air from the engine through where the pedal box sits on the foot box...tryed duck tapt and insulation tape both came loose from the heat!
How about silcone...would it hold up under the heat??? any other suggestions?
Jon
Old 09-17-2010, 07:21 AM
mickmate's Avatar
The black silicon caulking will work good, there is also some good seam sealers in a caulking gun tube I just used from NAPA. That worked well as it really builds up and seals a huge gap.
mickmate
http://www.actoncustom.com/
Old 09-18-2010, 07:03 PM
Cobra Make, Engine: A&C
I ran a piece (18x18") of sound/heat material across the the bottom of the pedal box from the bottom. First I cut slits for the pedals. It helped a lot.
Old 09-18-2010, 07:13 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Question
Have you got a photo of the area you're talking about?
Hersh
Old 10-03-2010, 10:51 AM
http://eddytheb.com/projects-in-prog...obra/?pid=1550
http://eddytheb.com/projects-in-prog...obra/?pid=1551
