Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree1Likes
Old 10-30-2011, 05:25 PM
Cobra Make, Engine: A&C Cobra, 521 CU BBF, Holley ProJection, T56 Magnum, 3.5:1 TruTrac 9-inch
I used the radiator that factory five sells for big block fords. I also bought a universal aluminum radiator mount and run a pair of 5000 cfm slim line puller fans. I mounted the radiator tilted back towards the engine. Scrapped the weird mount that a&c gives you. The factory five radiator was pretty cheap at only around $200 and it holds my 521 at about 185-200. I can post a pic of the mount setup if you need
Driving fast keeps you young. Just ask Einstein....
Old 10-30-2011, 07:55 PM
Cobra Make, Engine: Hunter - 427
Default Mount
Sspano,
I would like to see the mount. The A&C works but I'm not a big fan of the forward mount. Did you have to carve up the fiberglass coming from the front opening to get the backward lean?
Thanks
Joey
