01-13-2012, 04:33 PM
Cobra Make, Engine: A&C Cobra, 521 CU BBF, Holley ProJection, T56 Magnum, 3.5:1 TruTrac 9-inch
### New Springs
Hi folks
i am thinking of changing my coil springs. I am using the 'factory' setup that comes with the kit from A&C (not yet sure what the shock and coil rate is - does anyone know?)
My cobra only has about 2.5-3 inches of clearance. lowest point being the transmission bellhousing lip (quicktime). then the oil pan is the lowest point after. i will probably change the oil pan to a "normal" pan rather than the extra capacity moroso i have on there now.
i really dont want to cut the bottom lip of the bell housing, but maybe i will do that.
at any rate, i'd like to get overall 4-4.5 inches of clearance. so i want to swap the springs to some kind of a taller, progressive rate spring, so I can get a little bounce at the top, but then have the spring tighten right up so the car doesnt bounce 4 inches down to the ground.
has anyone swapped their springs and or shocks? any recommendations?
Driving fast keeps you young. Just ask Einstein....
